karlb Posted July 13, 2011 Share Posted July 13, 2011 whats the go with changing an engine that is injected to run carb? reason being iv found a g63 which is efi out of a 92 chariot its cheap and was going to rebuild it. what would i need.and also will it work? thanks in advance Quote Link to comment Share on other sites More sharing options...
OSM Garage Posted July 13, 2011 Share Posted July 13, 2011 Guessing its the SOHC 4G63, its easy to convert efi motors to carb. They still use a distributor/have provision for a distributor. Replace the inlet manifold for a carb'd manifold, slap in your dizzy and your away! Mr PW may inform in more detail but is definitely do-able Quote Link to comment Share on other sites More sharing options...
