Everything posted by karlb
dash has a couple of very little cracks which have been filled with a special dash repair goo.and the rust in the engine is all gone. new plates welded in there. engine bay was taken back to bear metal epoxy primed, 2k primed then 2k white top coat
Not much of a update but thinking of selling this. will put up current photos over the weekend
i was thinking of using to paint my x-member and steering components. after giving them a sand blast was thing of etch priming them and then using the 3m chassis black.
Hey guys anyone used the 3m chassis black paint from supercheap? whats it like?how does the finish last? cheers karl
well iv gone done a differnt road again. sold the 4g63 and gone back to the g32. what is your adivce on carb set up?run the standard or use a weber 32/36?
hey man do you know what clutch system you used in yours?
what clutch system do i need to use?do i need to go to auto clutch and get one custom made?
hey guys trying to get quotes to get a motor from mastern to auckland. But need to know the weight of a 4g32 (1600cc) motor. can anyone help out
are you selling any other parts off your other ex lancers?
when i went to do the compression test and take out the spark plugs 2 were very loose. -done the test all tested good. -put back together and warmed up and test drove -once warm rang the titties out of it -no more problem so would the 2 spark plugs that were very loose cause this problem.guessing it wouldnt have been producing a good spark and sucking in air? cheers karl
anyone in the south auckland area got a compression tester i could borrow for half an hour??
yea started yestrday.will probilly take the head off on friday. or will it be best to compression test it first??or just pull it apart.
I know this isnt old school but need some help My misses has got a 92 fx corolla with a 4a-fe in it. She was on her way home yesturday and just about over heated it. then next minute i get a text saying help cars stopped. Went out and checked it. it had no water so i filled it up with water and drove it home only 2 mins to home. half hour later went and checked it- no water, checked it out and the bottom radiator was f@#*ed So tonight got a brand new radiator in it and warmed it up- all ok. took it for a drive around the block - got half way and it started missing and sounding like a subaru. just as i got home my brother turned up and said it popped head gasket. There is no water in the oil and vase a versa. guessing its popped the gasket and leaking air?? any help will be great
i was thinking that but yea same again trying to find a 10 bolt sigma is gona take a while. should have stayed with the 8 bolt lsd at least i could of used the other axles
iv snapped the axle in my 10 lancer diff. as you all know these are very hard to get hold of. what axles that are easlier to get hold of to fit in there? cheers guys
check his site on what he does etc thesteelsurgeon.co.nz
for a car (road wheel) he now charges $120 per wheel and yup he does/ can flip the centers
did a bit on it this weekend got the rust below the washer bottle removed and welded a new plate in and epoxy primed the front panel. just got a 8 bolt lsd and this weekend ill try and take some more pics. after i tig weld the strut towers and seam weld the front and rear end
sorry its a 32-36 dgav and going onto a 4g63 sohc
hey guys, Iv got a weber carb and unsure of what engine rating its jetted for. im wanting to jet it for a 2L. what jet sizes do i need? thanks karl
iv borrowed this photo from bigA and was wondering if it would work in the old lancer
thanks man will call him tomorrow. i take it there nicely balanced iswell?
who in auckland widen's wheels apart from arrow wheels. also what price does it range between? looking at getting some 14's widen
well pulled the motor out of the sigma today. the gearbox bolts up no problem there. and im guessing im gona have to use a sigma flywheel as its a 6 bolt crank. so i think im also going to have to use a g63 clutch iswell.
shit only read this now.been pretty slack lately. its a narrow block out of a 81 sigma with auto. will i need to get a 4g63 flywheel and clutch setup?or use the 4g32 set? cheers karl
