Gaz Posted May 31, 2011 Share Posted May 31, 2011 Question on the fuel pump im about to put in tomorrow. As you can see in the below pic the outlet is a funny fitting which looks to have a little valve in it. I am assuming that this is how the fuel pump knows when to stop pumping at full go? If so my question is answered and all I need to do is go find a fitting to go onto this and clamp my 10mm hose up to. Can I use the old na fuel line as the return or should I also run 10mm return line? Engine is x20xev. Cheers Fuel pump = this. Uploaded with ImageShack.us Quote Link to comment Share on other sites More sharing options...
kpr Posted May 31, 2011 Share Posted May 31, 2011 fitting is a one way valve to stop fuel drain back. so pump doesnt run dry after its been sitting. your stock feed should be fine as the return, long as it isnt tiny Quote Link to comment Share on other sites More sharing options...
Gaz Posted May 31, 2011 Author Share Posted May 31, 2011 Ok will go find a fitting to go on it tomorrow then. Return line is standard Chevette so will be small 6mm. So does the pump ever slow down once car is running or is there always enough fuel running in a circuit to feed the engine at whatever revs.. i.e does pump run all the time? If so then surely 6mm is too small? FYI running standard ECU Gaz Quote Link to comment Share on other sites More sharing options...
kpr Posted May 31, 2011 Share Posted May 31, 2011 pump runs full speed all the time. 6mm return should be fine with that pump. if you wanted to, could check the fuel pressure. will tell you if the return is too small. (pressures too high) return is pretty much allways smaller than the feed Quote Link to comment Share on other sites More sharing options...
Gaz Posted May 31, 2011 Author Share Posted May 31, 2011 Sounds good will hook it up like this and go from there. Cheers for the help. Gaz Quote Link to comment Share on other sites More sharing options...
DJZ Posted May 31, 2011 Share Posted May 31, 2011 It should have a banjo fitting & enclosed nut on it. I got one from pick a part off some sort of 80's Euro, might have been a BMW. The other one I bought from NZ Performance which was a bit of a rip but he had them in stock. http://www.nzperformance.co.nz/store/bosch-fuel-pumps/banjo-kit/prod_717.html Quote Link to comment Share on other sites More sharing options...
Gaz Posted May 31, 2011 Author Share Posted May 31, 2011 Thought it would be a banjo, Will grab one tomorrow from somewhere. Gaz Quote Link to comment Share on other sites More sharing options...
