originalrx Posted May 26, 2011 Share Posted May 26, 2011 Why do they fuck out when it wet/rains? Take ages to start evan if they start that is. Also door locks stop working Can anyone tell me why and how to fix? Cheers Quote Link to comment Share on other sites More sharing options...
glen Posted May 26, 2011 Share Posted May 26, 2011 guessing it's water and moisture getting on the electics. used to have a old 86' GL corrolla used to start missing in heavy rain due to water flicking up on dizzy/ everything. was a cunt. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted May 26, 2011 Share Posted May 26, 2011 pull apart everything and give them a good dry out, better if you can do it with some compressed air. Re assemble and spray over dissy, leads and coil lead with crc. that should hopefully fix your woes Quote Link to comment Share on other sites More sharing options...
nothingsfree Posted May 30, 2011 Share Posted May 30, 2011 Also check the wiring/relays etc behind the kick panel at the bottom of the drivers A pillar. dx's have a habit of collecting water in the corner of the wiper tray and then rusting out. Then when it rains the water runs straight down into all the wiring etc.. Quote Link to comment Share on other sites More sharing options...
