rawismore Posted March 15, 2011 Share Posted March 15, 2011 Some grinding scraping noises have emerged from the back left of my mk2 escort this past week. more noticeable when turning right. These are a pressed fit item correct? wheres a good place in central auckland to get done? bit of a mission pressing yourself correct? Quote Link to comment Share on other sites More sharing options...
Mr. Mainstream Posted March 15, 2011 Share Posted March 15, 2011 check rear diff has oil, could be the case. if it is wheel bearing they cost next to fuck all for them and to fit at any coherent workshop in auckland id imagine Quote Link to comment Share on other sites More sharing options...
rawismore Posted March 15, 2011 Author Share Posted March 15, 2011 havent checked diff oil but i suspect the bearing is the case, has a rather loud and metal on metal knocking noise when hitting a bump with the back left wheel Quote Link to comment Share on other sites More sharing options...
Hemi Posted March 15, 2011 Share Posted March 15, 2011 sure its not the shock or spring bushes being fucked?? , or somthing loose in the boot , reason i say this is because wheel bearings tend to make more wop wop or rumbling sounds. have you checked for play at all?? Quote Link to comment Share on other sites More sharing options...
Unclejake Posted March 15, 2011 Share Posted March 15, 2011 Agreed. It doesn't sound like a bearing to me either, but get someone to check it out. Quote Link to comment Share on other sites More sharing options...
