4 stud ford diffs
wickmyster
  • Replies 51
Is the VL gear interchangeable with XA falcon stuff? I have a 2.92 XA falcon diff sitting in my shed. Would a XF LSD head go into the XA housing?
I am a bit ignorant on Borg warner obviously..
You can use VL gears in an XA housing with an XF lsd center. It's not a straight swap though. I'm not sure about LSD centers that used 2.77 gear sets thoughhttp://www.trademe.co.nz/Trade-Me ... 669107.htm
your XF LSD would work well in this.
How does the place in Hamilton intend to shorten the axles? for $400 i'm picking they will be cutting and welding them.
What about a mazda diff?
http://www.trademe.co.nz/Trade-Me-Motor ... 907252.htm
Stud pattern is close enough to 4x108 & can get LSD heads too.
Gaz
Be carefull though LSD centers for these could be expensive, it will probably have rotary suitable 4.1/1 ratio too.
Cheers, You've been I mega time saver Valiant
Will check how he shortens them, is cut an wielding bad? I will still be under 200hp so will it matter? How do they do it normally?
I know other people that do it cheap as my cousin is an engineer...I might get a quote from him to shorten a diff
Also Bruce Greer near Waihi (in waikino) is meant to be very good, and that is closer the Hamilton.
