RUNAMUCK Posted January 12, 2011 Share Posted January 12, 2011 Hey, Are you mates with Josh with the Z18et powered datsun 1600? I saw a KE20 very much like yours at his house aa while back. Quote Link to comment Share on other sites More sharing options...
rbke20 Posted January 15, 2011 Share Posted January 15, 2011 Hey yes I sure am did you do the wiring on his datsun Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted January 15, 2011 Author Share Posted January 15, 2011 Nah. thats another mate of mine. When you say your leaves have been flattened out, did they remove all the elipse from them? In my experience leaves that have no curve in them have real trouble putting power on the ground. They need the shape to "hold" the tyre on the ground. And with the power you'll have on tap, you're going to need all the traction you can get. If I ever get my leaves reset, I'd get the eyes reveresed for certain. Quote Link to comment Share on other sites More sharing options...
rbke20 Posted January 16, 2011 Share Posted January 16, 2011 Thank you for that I will be sure to check that out.Would you have any other ideas of what else i could do to keep the strength there.I really wanted to put a independent rear end in it to be honest Quote Link to comment Share on other sites More sharing options...
Truenotch Posted January 16, 2011 Share Posted January 16, 2011 a 3 or 4 link with watts or panhard rod is the best way to run... Much simpler than IRS and you can get LOTS of traction (or no traction if you'd prefer). If you want a simple fix - tramp rods on both sides of the diff (mounted from the top), good shocks and the right leaves will be reasonable. Check lownslow's escort thread for a general idea. Quote Link to comment Share on other sites More sharing options...
