StuT Posted November 26, 2010 Share Posted November 26, 2010 Hi All, Have searched with out luck for help on this. Wanting to fit Dellorto 40's side draughts on a 1600 Capri (Kent engine) but looks like brake booster going to be in the way. Not really wanting to change brake setup yet, just trying to drop stronger engine in. Is this a problem on Escorts too? Any idea where to get appropriate manifold to sort this out? Thanks Quote Link to comment Share on other sites More sharing options...
Escorto. Posted November 26, 2010 Share Posted November 26, 2010 Yes it is a problem with escorts too. i just unbolted the booster from the wing/inner guard and lowered it to clear the crabs works good. im going bias box soon tho. need room for my sr20det. Quote Link to comment Share on other sites More sharing options...
pusherman Posted November 27, 2010 Share Posted November 27, 2010 i fixed this prob in my escort. took a samll amound of fiddling to get the booster bracket out, you dont have to take the actual booster out or disconect any brake lines. then stuck the firewall end of the bracket in the vice gave it a bend bolted it back to fire wall and re drilled 2 holes in inner guard for the bracket bolted that baby up and hey presto twin sideys fit a treat Quote Link to comment Share on other sites More sharing options...
