Hi all
Question about putting in an overflow tank on to my Capri.
Does the tank need to be higher than the radiator or set low okay since should work on pressure?
No real room for up high would be half way down radiator on side of engine bay.
Thanks in advance
So situation is my 3 litre essex is getting tired and needs rebuilding.
I do have 2 other ford v6 engines but not sure what they out of or size
Hoping the are compatible so can build a good one with my heads and cam etc
Dipstick on front not side
Any help appreciated thanks in advance
Most additives say they help stale fuel and water in lines etc.
As for carb yes pull down ideal but looking to buy new 38 soon as current 40 webber on last legs
Hi, anyone used a fuel system additive in a carb engine?
Just wondering on any benefits of flushing out stuff.
Or any sucess with octane boosters?
Running old essex v6 with 96 and lead additive.
Cheers
Wow thanks for that didn't know the laser option.
I have the v6 mark 1 hubs which have a bigger deeper hat shape. Same as oz cortina. Not same as the most capri's escorts
Q. Has anyone fitted one of those atlas watts linkage kits to there escort?
Looking to do to my capri to tighten up rear end.
Seems best solution, bushes etc all good
Manage to find some replacement rotors thanks to help from bnt.
Don' t ask for v6 capri rotors ( everyone lists them wrong) order v6 cortina ones. Problem solved.
