LingLing Posted September 28, 2010 Share Posted September 28, 2010 Ok,Firstly, Thanks For those of you answered my previous questions and this one. The low beam,park light, high beam all work fine. The problem is on the switch( I assume). It works on normal driving(low beam on, park lights on, no high beam), also works on the flashing(High beam on while you press it). But While I switch my car on High beam, All the front lights(park,High,low beam) shut off. I assume I need to replace the Switch? Anyone got some experince with this? Quote Link to comment Share on other sites More sharing options...
anhonyb Posted September 28, 2010 Share Posted September 28, 2010 this was happening to me also, i just cleaned up the earth wire at the headlights and it all worked Quote Link to comment Share on other sites More sharing options...
LingLing Posted September 28, 2010 Author Share Posted September 28, 2010 Can you please explain it bit more? Quote Link to comment Share on other sites More sharing options...
anhonyb Posted September 28, 2010 Share Posted September 28, 2010 there was a black earth wire coming from my headlights but it was attached loosely and painted over so i just sanded it and attached it securely to a good earth and it fixed my high beams Quote Link to comment Share on other sites More sharing options...
LingLing Posted September 28, 2010 Author Share Posted September 28, 2010 Ok, I will have a look. but my high beam works while I just Flashing it. Doesn't work while I switch to it. Quote Link to comment Share on other sites More sharing options...
LingLing Posted September 28, 2010 Author Share Posted September 28, 2010 Disassembled the whole Left Front light Area, Can't find any earth wire. dam. Quote Link to comment Share on other sites More sharing options...
kyteler Posted September 28, 2010 Share Posted September 28, 2010 Yeah, just likely to be the cluster. Get one from a wreckers, put it in, bam. Job done. Quote Link to comment Share on other sites More sharing options...
