takes a while to start after sitting?
Beaver
right, replaced the one from the battery to the solenoid, that was in pretty bad shape. Also cleaned all the contacts and shit. Turns over heap quicker. Couldnt be fucked shifting the motor earth as ill have to get under that car, and i plan on sleeping in tomorrow so it should be warm by then haha
but yeh, next ill shift the motor earth
  • Replies 41
As someone said - make sure you are running the correct coil. I was running a non ballast coil in the capri, even though i have a ballast resistor. Didn't notice for a while until i started having trouble starting the car when cold. Also chewed through points more than usual if i remember right.
So check that out.
