Beaver Posted March 2, 2010 Share Posted March 2, 2010 hey all got a few issues with the indicators in my cortina. if i indicate right, they work fine (flash rate seems to be a touch irradic however) but if i indicate left, the light on the dash flickers rapidly, the flasher unit ticks rapidly, and only the front indicator lights up (but very dim, and flashes rapdily obviusly), the flasher unit alsio gets very hot when indicateing left. i tried a different flasher unit, again work fine on right, but when left, the unit smokes...whilst ticking rapidly. can anyone recomend a place to start looking? i swapped out the bulbs for working ones but this didnt fix anything. i also tried a different indicator stalk/assembly and got the same results. cheers Quote Link to comment Share on other sites More sharing options...
kyteler Posted March 2, 2010 Share Posted March 2, 2010 Sounds to me like blown/incorrect bulbs or bad earths so one of the bulbs isn't working. When you say they flash fast, are all appropriate lamps flashing? one might be a different voltage or wattage from the others and thus causing issues. Quote Link to comment Share on other sites More sharing options...
Beaver Posted March 2, 2010 Author Share Posted March 2, 2010 all indicators were working properly, until i pulled the indicator stalk assembly apart to try fix the headlights (long story....). after reassembly they started playing up as desribed, so i tried a different stalk/assembly, but with the same results (which leads me to think its not the indicator assembly, but further along in the wiring). also im 99.9% sure its not the bulbs, due to them working and me no changing them since. i changed the left back bulb (which doesnt flash at all) to a bulb i nkow works (was from the right side) but it still didnt flash Quote Link to comment Share on other sites More sharing options...
- i5oogt - Posted March 2, 2010 Share Posted March 2, 2010 one other thing is to check that all the bulb holders have good contact with the tail and park light assemblies on the mk2 Quote Link to comment Share on other sites More sharing options...
Beaver Posted March 2, 2010 Author Share Posted March 2, 2010 cheers, will have a nosey tonight Quote Link to comment Share on other sites More sharing options...
Beaver Posted March 3, 2010 Author Share Posted March 3, 2010 got it sorted, turned out to be a dodgy bulb...... haha hopefully have time to take it in for a wof tomoro Quote Link to comment Share on other sites More sharing options...
kyteler Posted March 3, 2010 Share Posted March 3, 2010 I WIN! Quote Link to comment Share on other sites More sharing options...
Beaver Posted March 3, 2010 Author Share Posted March 3, 2010 haha yeh my bad. it was a combination of a dud bulb and the wrong bulb bay Quote Link to comment Share on other sites More sharing options...
