Z-M-K Posted August 26, 2009 Share Posted August 26, 2009 Ive purchased a 1982 mitsi Ex and its a 1600 automatic. What is needed to make it manual? clutch, gearbox, pedal kit, flywheel, driveshaft? diff? Thanx again, Z-M-K Quote Link to comment Share on other sites More sharing options...
kyteler Posted August 26, 2009 Share Posted August 26, 2009 Spigot Bushing, Flywheel, Clutch, Pressure Plate, Clutch Fork, Clutch Release Bearing, Gearbox, Drive-shaft (in some cases, others not), Pedals, Assuming it's Hydraulic; Clutch fluid line, Clutch Master Cylinder, Clutch Slave Cylinder, Interior Fascia (ie. Manual Gear Lever Boot, etc) Re-wiring (loop) to bypass the Auto Lockout. A jack, some axle stands, some gearbox fluid and about 4 hours. Quote Link to comment Share on other sites More sharing options...
Z-M-K Posted August 26, 2009 Author Share Posted August 26, 2009 Thanx mate, ill start looking for parts now. Quote Link to comment Share on other sites More sharing options...
kyteler Posted August 26, 2009 Share Posted August 26, 2009 Likely easier to find a manual shell, that way you can rob the parts and see where they have to go at the same time. Or you could have just started with a manual EX Quote Link to comment Share on other sites More sharing options...
Z-M-K Posted August 26, 2009 Author Share Posted August 26, 2009 good idea, ill look for wrecking ex lancers, could never find one as tidy as the one i found. Quote Link to comment Share on other sites More sharing options...
kyteler Posted August 26, 2009 Share Posted August 26, 2009 Fair enough, good luck. Quote Link to comment Share on other sites More sharing options...
lowlancer Posted August 26, 2009 Share Posted August 26, 2009 Cable clutch up in this bitch. Should still have the firewall hole. Quote Link to comment Share on other sites More sharing options...
Requiemk Posted August 26, 2009 Share Posted August 26, 2009 you'll need a manual alternator as well to get it running nice Quote Link to comment Share on other sites More sharing options...
