Jammy-Fishpaste Posted April 20, 2009 Share Posted April 20, 2009 i know its not OS but the car is a G100 Daihatsu charade GTti the problem: in certain situations when driving and ALWAYS when your turning right it will not rev and decellerated, as if its not firing. it coughs and splutters after this and wont rev properly but clears within a few seconds of straightening out. so far ive replaced - the battery, the coil and ignitor, the leads, the WHOLE distributor, the spark plugs. ive also cleaned the fuel filter, blown out the fuel lines and rail, replaced the fuel. the problem is it idles fine and revs fine when stationary and even drives fine accept when turning right and trying to accelerate when doing so. ive looked at the wiring around teh steering column and theres nothing up. mive checked all around the steering arms and cvs and anything to see if any wiring is getting caught in anything and its not, ive reterminated a whole fuckload of wires and that hasnt helped.. SOMEONE PLEASE HELP ME BEFORE I GET TOO ANGRY AND DO SOMETHING STUPID Quote Link to comment Share on other sites More sharing options...
UTERUS Posted April 20, 2009 Share Posted April 20, 2009 Does it do it when you are stationary and you turn right? Try jacking up the right hand side as far as your jack will go and wiggle your wanger/wires/something else electrical or fuel related. Do a skid. Quote Link to comment Share on other sites More sharing options...
Unclejake Posted April 20, 2009 Share Posted April 20, 2009 Pull random wires to the left while at idle, including the coil and fuel pump and if nothing shows up consider fuel surge as a possibility too Quote Link to comment Share on other sites More sharing options...
Jammy-Fishpaste Posted April 20, 2009 Author Share Posted April 20, 2009 no its only when moving, asthough the momentum is causing something to not work. :s skid done. lol Quote Link to comment Share on other sites More sharing options...
Jammy-Fishpaste Posted April 20, 2009 Author Share Posted April 20, 2009 how can i tell if its fuel surge? how can i fix this. replace FPR? Quote Link to comment Share on other sites More sharing options...
Unclejake Posted April 20, 2009 Share Posted April 20, 2009 how can i tell if its fuel surge? how can i fix this. replace FPR?Dunno. ......... jokes. Still dunno. Are you running metric fuel? Quote Link to comment Share on other sites More sharing options...
Jammy-Fishpaste Posted April 20, 2009 Author Share Posted April 20, 2009 whats metric fuel? ive got 91 unleaded in it, should probs have 95 but didnt have any adn am out of town, has run fine on 91 for ages. Quote Link to comment Share on other sites More sharing options...
Unclejake Posted April 20, 2009 Share Posted April 20, 2009 whats metric fuel?. It is UJ code for "Sorry, I am out of ideas as I don't know the particular engine well enough" Quote Link to comment Share on other sites More sharing options...
Jammy-Fishpaste Posted April 20, 2009 Author Share Posted April 20, 2009 o well, cheers anyways. am off to change the fuel pressure reg adn see if that helps. Quote Link to comment Share on other sites More sharing options...
Unclejake Posted April 20, 2009 Share Posted April 20, 2009 If , and only if, you can kill the ignition when the fault occours you could whip the plugs out to see if they are wet. Wet (with fuel) would = electrcial. it would be a bit hit and miss though Quote Link to comment Share on other sites More sharing options...
UTERUS Posted April 20, 2009 Share Posted April 20, 2009 When it stops, does it splutter or cut out instantly? From experience spluttering = fuel, instant cut out = electrickery related. Quote Link to comment Share on other sites More sharing options...
Jammy-Fishpaste Posted April 20, 2009 Author Share Posted April 20, 2009 all things point to it being fuel, might end up having to pull the fuel tank out and clean everything. Quote Link to comment Share on other sites More sharing options...
Unclejake Posted April 20, 2009 Share Posted April 20, 2009 Start at the other end. Check the fuel filter first Quote Link to comment Share on other sites More sharing options...
UTERUS Posted April 20, 2009 Share Posted April 20, 2009 How much petrol is in the tank? Where abouts is the pickup inside it. Quote Link to comment Share on other sites More sharing options...
Simon Posted April 20, 2009 Share Posted April 20, 2009 Maybe those MOFuking kids next door had been putting bark and stones in the tank like your aw11. Put more petrol in the tank. Mothers car surges hard when the tank gets below half. Carb fuel tank on EFI car means no baffles in tank. Quote Link to comment Share on other sites More sharing options...
forced Posted April 20, 2009 Share Posted April 20, 2009 Does it have an alarm? Steve Quote Link to comment Share on other sites More sharing options...
Jammy-Fishpaste Posted April 20, 2009 Author Share Posted April 20, 2009 yeh i need to put more fuel in. changed fuel filter, didnt help. cleaned rail and lines at engine end out, blew down fuel line and retern line. i think its at the pickup. is a cunt to take tank out of too. Quote Link to comment Share on other sites More sharing options...
