cute wee gem Posted January 23, 2009 Share Posted January 23, 2009 Got engine in last night, everything seems fine except it won't fire when the key is in the normal run position but will have spark when cranking it over on the "start" position on the key. Idea's so far are a dirty/corroded ignition switch. Is there a certain relay that has anything to do with this? Has me fucked anyway Quote Link to comment Share on other sites More sharing options...
QCADTA Posted January 23, 2009 Share Posted January 23, 2009 Do you have power all the way through the positions on your ignition barrel? eg acc. , on position etc? Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted January 23, 2009 Author Share Posted January 23, 2009 Yep checked that earlier, got it sorted now, she runs Quote Link to comment Share on other sites More sharing options...
Unclejake Posted January 26, 2009 Share Posted January 26, 2009 Yep checked that earlier, got it sorted now, she runs Choice. Ballast resistor wired up wrong? Quote Link to comment Share on other sites More sharing options...
lowlancer Posted January 26, 2009 Share Posted January 26, 2009 Yep checked that earlier, got it sorted now, she runs Choice. Ballast resistor wired up wrong? Or the relay associated with it would have been my pick? Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted January 26, 2009 Author Share Posted January 26, 2009 yep, converted to electronic ignition and realized the ballast wire went all the way to no where/dizzy when it should just go straight to coil Quote Link to comment Share on other sites More sharing options...
lowlancer Posted January 26, 2009 Share Posted January 26, 2009 Thought you didn't need ballast resistor on electronic ignition cos the coil can roll allsorts of voltage? Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted January 26, 2009 Author Share Posted January 26, 2009 Meh, problem's fixed and it works. wire running in won't reach to coil anyway and it's doing no harm with the ballast in there. Quote Link to comment Share on other sites More sharing options...
