plasticdash Posted January 18, 2009 Share Posted January 18, 2009 Would anyone know the differences between rx7 S4 and S5 gearboxes? (and if the turbo/non turbo ones are different) , so far the info i have found is that the S5 gearbox has more strengthening ribbing? I have a bellhousing to fit one of the above into the starion, and am looking at purchasing a box, would like to get the strongest one possible. Quote Link to comment Share on other sites More sharing options...
sentra Posted January 18, 2009 Share Posted January 18, 2009 there both much of a muchness in terms of strength there strong as but are all old as fuck now non turbo ones are rubbish s5 have the mounts on an angle i.e \___/ with the holes to mount the box on the / bits s4 mounts are flat on the bottom. seeing you have a bellhousing, you can also use s6 onwards (the input shaft length is 10mm diffirent from memory, i cant remeber which way) but youl have to devise some funny way to mount it or weld something to the rear housing. i think you can also use the early rear housing and get the remote gearshift that you can move to suit your gearstick hole, where as s6+ the shifter position is fixed. (but the deisgn of it is shitload better in everyway, i.e youd want to keep it) cause you can get s6+ boxes for the same price as s4/5 ($500~) but there a shitload newer, in less of a need for a rebuild, and noone bothers with them for early stuff. inside their pretty much idnencle / much the same shit again/ not worth mentioning. Quote Link to comment Share on other sites More sharing options...
sentra Posted January 18, 2009 Share Posted January 18, 2009 on the teamfc3s.org website you can also get the fsm which has all the gearbox info you want for them 1 Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted January 19, 2009 Share Posted January 19, 2009 Not sure how to tell them apart externally, but the ratios are much better on S5, heaps closer and have a shorter throw too. Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted January 29, 2009 Share Posted January 29, 2009 I've never seen a factory manual convertable, always thought they were all auto. Quote Link to comment Share on other sites More sharing options...
