bubblegooses 79 lancer, nothing left alone spec
bubblegoose
  • Replies 92
thought id make a heat shield for teh fire wall and stuff. note also water outles welded onto water pump to avoid rangi hacking of fwd pipework
then fitted my 'close tolerance' zorst
took my fucking hours to get them on and scratched the shit out of most things in the engine bay and had to unbolt engine aswell
filled engine with oil
took cambelt off again
put drill on oil pump
coverd floor with million oils
im missing two blanking grub screws from the zorst side of the block
POOS!
have also made a pretty sweet gauge cluster for new dash, painted fuel gauge all black and replaced empty with a red dot, replaced water temp gauge with autoMETER ARF gauge rotated 90' and blacked out for max hidden spec
so that ^ was me making a jig to bolt my subframe too
then the jig got attacked with a drop saw and 100mm removed, measured carefully with my eyes to make sure its still all boshty and welded back together
then the subframe got the drop saw treatment and the usefull ends bolted back to the jig
more has been done/its short now i just dont have any pikychurs :(
that will bring the diff to 1400mm about right for my ryums (its a 4wd rear aswell so running 14x14s will be easy as pye)
AHAHAHAHA! yeah
started making a TREX stainless strut brace
got the subframe down to a respectable 1350mm
but welded and diamond plated
doesn't quite line up in some places so some stiffening was added (and a bit more will be)
still rough and unfinished but its going to get thrown around a bit now so im not getting worried till the end
have some 20v itbs and a 12mm flange to play with aswell
