bubblegooses 79 lancer, nothing left alone spec
bubblegoose
  • Replies 92
RE:sump wont last five minutes
now holds about 400mls more oil, has 25mm wide skid rails folded over on the bottom to be 4mm thick. a front skin of 1mm steel (no oil behind it) then the main oil pan is remade from 3mm thick sheet and has a low profile sump plug :wink:
i here by challenge anything to penetrate my oil pan :badgrin:
and yes i deliberately left it whorey looking to scare hedgehogs out the way
spendy......very spendy
but i did get to do this :D there all together at last
poor pic but now in the 3rd revision, they have been brace top and bottom and have mounts fitted for a more modern approach at sway bar links and a new lock stop
some go faster bits, nology leads and a holley blue pump
stripped cleaned and then...... left, need to re drill the mains to 1.8 and lift the needles up a clip (i hate that job i always loose the tiny springs)
just need a new cross member and i can start throwing it all together
thought id flip the ring gear over to the fresh side, had the dryer on in the garage (mega humid) which made a thick layer of ice over my frozen flywheel. was so hard to not lick it :lol:16141_187184284765_530014765_3753218_4421586_n.jpg
there finally all in place with the brake lines all fitted etc
SHIT! where did that bit get too, time for a treasure hunt
found it :lol: was in the container of bolts for the old front struts :rolleyes:
r1 carby school time
in the top of the slide you will see this lil white tag
carfully pull it out with needle nose pliers, BE CARFULL there is a stupid little spring behind it (dont be tempted to push it out with the needle they bend too easy)
this is your buried treasure, the stock position for the circlip is the middle groove
i dropped my clip down one notch, dont forget to replace the little plastic spacer if you do your car will run like a dead dog
easyest way to replace it all is to fit the needle into its hole the lift it back up and hold it steady while the replace the steel washer, spring and lock tab
keep pressure on the spring while you push it back and lock it into place then check the needle is still free (few mm movement) and has spring tension
repeat 4 times
so i required some bits to finish of my engine
mainly these (was missing some bolts aswell but meh)
yes i work on my car in pitch blackness
brought an entire engine (for $22) to take off any bits i needed then scrap all the alloy for max profit
apparently had blown head gasket due to blocked radiator, umm nah i think it got hot cuz of this
cambelt wasnt too old either :doubt:
seems it was driven on for a while in said condition
and wait..
they let me have a magic pen and some drugs :lol:
not done alot really
center console is all cut out for my shizzle, just need to get the textured paint on it now
one more coat of paint then clear coat it, also getting the car reprayed this yellow :D nah just kidding its the same yellow as the engine bay but with more flash on it
car will be fully resprayed in ppg base and clear *cough*for free*cough* to match my engine bay paint as i likes it more than the current lellow
new fancy trigger wheel and intake trumpets total cost $40 :D
crap picture but my engine and box are fitted (currently on grahams engine mounts)
can now sort out my plumbing
have smashed out the dent in the rear panel will fill that full of green cheeze later
need to get my seats sorted and want to do my headers again and make them look complicated
moved a brake line and made a heat shield, have discovered the worlds best brake line brackets. will move the rear line when i can be arsed
got a new dash with guage holes in it, not sure iff ill use it or not.
couldn't make my mind up
then i did that and they looks the bizzle :D
have a ghetto flow bench in the makings aswell
