bubblegooses 79 lancer, nothing left alone spec
bubblegoose
  • Replies 92
compare it to the first pics, its lower but now low enough
have also found a new issue, starion hubs lock out before lancer hubs. this is full lock so more mods will be needed (steering rack conversion at the same time)
doesn't even hit the stops properly, oh well more cutting and welding then
this is how to remove axle bearings :badgrin:
got the engine and box out, got half way through stripping box, (expecting it to need new bearings and syncro's) then with a look of disbelief put it all back together again due to the uber mintness of everything :shock:
some plonker fitted the gearbox obviously :lol: (sorry) the shift lever bolts were loose as fuck (read: 5mm out of the hole) and that caused the levr to move too much and damage this hole...........so i weleded it :D its now round again
then performed some surgery to the shifter to remove that ghey push to shift bolox
scruba dub dubb
motor 90% assembled just need to finish fucking my head up and bolt it on
my pink bits :oops: that actually fit this time
CBA sitting in a cold engine bay so whaked out my
and painted my
should really finish the head so i can get the motor out of my way
oh and wasnt happy with the end bend in the over diff, so i chopped it up again now i have a floating flange :lol:
well, the other night while busy ferreting away in the garage i heard a slight nawwing noise in the back ground
so i went to investigate.
I found the legendary rust goblin!
this rare creature has never been seen before and the only previous evidence of his existence was his excrement left on the panels of old cars :doubt:
in other more exciting news i received some titanium headers to chop up
i made a head gasket
my engine fell in (please excuse sorry state of engine bay :lol: )
oh and wire brushes can penetrate 3 layers of clothes (also i dont like wire with barbed ends)
fuck i like to make work for my self, just made a purchase on the wonderful trade me
thought id just skip the bull shit of upgrading to a massive heavy rear axel and just do it right
also brought a stash of alloy sheets to remake the rear floor pan after i destroy the steel one
this will not be tackled for some time i want to blow the old diff up first
im not sure wWTF was going on with my welding on these bits
appart from that and staring to deloom the engine bay not alot has happend but im back in the mood again so more stuff should start happening :D
EDIT:
no wait actually the engine and gearbox are in (for now)
i spy R1 carbs :D
and i managed to finish off those gauges (the flash makes the trim look poop)
well the last attempt at headers didnt work too well. the plan was to make the pipes then flare the ends to fit the shape of the ports, that failed! There wasn't enough give in the tube, so i chopped them up and salvaged some of the bends and started again but this time with the tube already made to fit :D
got the headers all tacked into place have carefully removed them (requires removeal of cylinder head to do so :lol: ) am not keen to weld them up till the last minute as i can see somthing will get in there way :rolleyes: so have started on the steering rack conversion
(started being the key word, other cars work and females are slowing me down atm :doubt: )
chopped the end off the rack to keep the ball joints level with the lower suspension pivots
its currently with a mate on waiting to go on his lathe to drill and tap the new hole for the tie rod
when it finally makes its way back i can begin measuring up how much i need to chop off the housing
hmm well ive been doing to tinkerbelling in the garage recently
and this be the resuslts
made a set of massive bonnet risers..... there also quick release :D
well you all know what they are
had to 'modify the shock .................. on the bench grinder :badgrin:
just a dummy fit
suffered this fatality with 25mm more shock left, hopefully with some lower tyres a bit of stretch and some discs behind the wheels it will help
but wait a second... im not sure i realy need the extra 25mm's :lol::lol::lol: the cell phone measuring stick wasn't going to cut it so i improvised with a $2 coin :wink:
