EURON8 Posted December 1, 2011 Author Share Posted December 1, 2011 So that nasty miss it was having recently was a combination of crappy carb tank pickup and no fuel Radiator is off at the shop getting the a bigger lower inlet and moved to the other side. Will make the lower piping much easier to sort out, considering 18rge water pump outlet OD is about 5mm bigger than radiator outlet OD. New battery. Oh OH oh, ALternator works a treat now. Cheers R100!!! Pre radiator removal. Quick sand and paint this week(ish) Quote Link to comment Share on other sites More sharing options...
EURON8 Posted December 3, 2011 Author Share Posted December 3, 2011 Spent ages out the back of repco comparing a wall of hoses to a piece of wire i bent into the basic shape i need for new lower radiator hose. Eventually found a winner from a commodore. WIth 80mm cut off each end it fitted pretty well. Radiator is back out and heading back the the shop on monday to get the top inlet altered as well and a nut for the thermo switch added. Couple of fiddly clearance issues left to sort. Like the brake booster hose rubbing on the coil mount and wearing through. Not actually as easily to fix as it sounds. story of my life. Am so going to do a burnout this week. Quote Link to comment Share on other sites More sharing options...
EURON8 Posted December 7, 2011 Author Share Posted December 7, 2011 Picked up my radiator again today. Had the top pipe angled down and a plug for the thermo switch added to top tank Picture of the odd direction the hose needed to go and how amazingly close the hose i found was. Quote Link to comment Share on other sites More sharing options...
EURON8 Posted December 14, 2011 Author Share Posted December 14, 2011 Slowly but surely. This rain is making things hard with the van being outside. Previous pipe had rusted out at both ends and was bordering on unusable, so raided a secret stash (rot808s bishes/boss doesnt know about my copper stash) of copper and got him to bend this up. Now to put radiator back in and test. Quote Link to comment Share on other sites More sharing options...
