Orange Posted November 25, 2008 Share Posted November 25, 2008 Hey, Basically failed a wof because of a worn out universal joint in my mk3 cortina, I have a complete manual 86 sierra wagon rotting out on a farm, does anyone know if the sierra drive shaft will fit in the cortina to save me from having to replace the universal joint? The cortina has a sierra gearbox in it and both cars have two piece drive shafts Cheers Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 25, 2008 Share Posted November 25, 2008 I would suggest if you have both cars on hand that you A - measure the necessary dimensions on both cars - if it is close then B - take them both out and line them up side by side and if you can confirm then C - fit it and check the splines and yoke.. Quote Link to comment Share on other sites More sharing options...
Raizer Posted November 25, 2008 Share Posted November 25, 2008 I am going to say no, but I can't remember why My old MK4 failed a WOF because the rubber doughnut was cracking and yeah I'm pretty sure the Sierra shafts don't work, think it might be something to do with the center mount. Quote Link to comment Share on other sites More sharing options...
Gaz Posted November 25, 2008 Share Posted November 25, 2008 I think your right. Have a funny feeling its slightly differant place. Quote Link to comment Share on other sites More sharing options...
Orange Posted December 3, 2008 Author Share Posted December 3, 2008 Yep... I tried it, it fit perfectly except the centre mount was in a slightly different place, I got the UJ replaced in the end. Quote Link to comment Share on other sites More sharing options...
Gaz Posted December 4, 2008 Share Posted December 4, 2008 So whats the centre mount bolted to? Quote Link to comment Share on other sites More sharing options...
Orange Posted December 8, 2008 Author Share Posted December 8, 2008 bolts? what bolts? it's cabled tied to the exhaust mounts... na but seriously, I got the universal joint replaced on the original mk3 drive shaft, I felt as that the drive shaft was too important to be messing around with it. Quote Link to comment Share on other sites More sharing options...
