Volvo 4 pots onto Escort/Capri - Help
treggo
  • Replies 67
edit...
Over $500!
240 British pounds = $513.208773 New Zealand dollars
Plus shipping.
Plus possible tax at this end.
Plus pads.
More like $600-700 landed and ready to go.
Think I member my research now and it was cheaper to buy from within NZ which was around the $450 mark. Do a search, I documented most of my prices etc.
Gaz
edit:
Here is some of it below. Prices are bout 2months old.
M16 outlaw pistons. Should be same volume as standard.
= 1.5" piston
Summit = $366 excluding shipping
Cardwells = $490inclusive
Willwood 120-6813 (Dynalite)
1.62" 41,1 mm .38" 9,7 Fits upto a 13" 330mm dia disc.
If can get away with using Dynalite piston bore size that are on price clearance at Summit at mo then can get for $276 exclud shipping.
Gaz
Completly stolen from another site but thought you guys might find some use in this.
Ford 2.9 V6 24V Cosworth 1995 - 1998
Vented
Mountings 4
Discs diameter 278.0mm
Discs thickness 24.0mm
Overall height 47.0mm
Centre diameter 63.6mm
Ford RS 2000 Cosworth 1995 - 2000 MK6
Vented
Mountings 4
Discs diameter 260.0mm
Overall height 43.8mm
Minimum thickness 22.2mm
Ford RS turbo 1986 -1990
Vented
Mountings 4
Overall height 58.1mm
Minimum thickness 22.8m
Ford Puma 1.7 - 2000 onwards
Vented
Mountings 4
Discs diameter 258.0mm
Discs thickness 22.0mm
Overall height 43.5mm
Minimum thickness 20.0mm
Peugeot 307 2004 onwards HDI
Vented
Mountings 4
Discs Diameter 266.0mm
Overall height 34.5mm
Centre diameter 66.0mm
Ford 2.8i Capri
Vented Disc
Mountings 4
Studs 4
Disc diameter 245.0mm
Disc thickness 20.0mm
Overall height 32.0mm
Hub hole diameter 68.3mm
Peugeot 405 1988 - 1996 MI-16 4x4
Vented
Mountings 4
Discs diameter 266.0mm
Discs thickness 20.5mm
Overall height 27.4mm
Minimum thickness 18.5mm
