Gaz Posted October 13, 2009 Share Posted October 13, 2009 Burtons shipping will kill it for ya. Plus price will be for one not two. Costs bout $500 for a pair landed without pads. Gaz Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 13, 2009 Share Posted October 13, 2009 edit... Over $500! 240 British pounds = $513.208773 New Zealand dollars Plus shipping. Plus possible tax at this end. Plus pads. More like $600-700 landed and ready to go. Think I member my research now and it was cheaper to buy from within NZ which was around the $450 mark. Do a search, I documented most of my prices etc. Gaz edit: Here is some of it below. Prices are bout 2months old. M16 outlaw pistons. Should be same volume as standard. = 1.5" piston Summit = $366 excluding shipping Cardwells = $490inclusive Willwood 120-6813 (Dynalite) 1.62" 41,1 mm .38" 9,7 Fits upto a 13" 330mm dia disc. If can get away with using Dynalite piston bore size that are on price clearance at Summit at mo then can get for $276 exclud shipping. Gaz Quote Link to comment Share on other sites More sharing options...
Sorensin Posted October 15, 2009 Share Posted October 15, 2009 What currency are those prices in and are they per pair or per caliper? The M16 outlaws look pretty good. Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 15, 2009 Share Posted October 15, 2009 NZD from memory. Jump on their site its pretty easy to add up. If a group buy can be had I could be interested. Gaz Quote Link to comment Share on other sites More sharing options...
Horse25 Posted October 16, 2009 Share Posted October 16, 2009 finally found some 4 pots that are vented at a wreckers in wellington, wants $200 for them, called heaps of places and struggled to find some, reckon they are worth the price? Quote Link to comment Share on other sites More sharing options...
Sorensin Posted October 16, 2009 Share Posted October 16, 2009 Couldn't find summit site... link? I sent a email away to palmside asking if we could get a special price for a larger order, they are $435 for a outlaw Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 16, 2009 Share Posted October 16, 2009 finally found some 4 pots that are vented at a wreckers in wellington, wants $200 for them, called heaps of places and struggled to find some, reckon they are worth the price? http://www.summitracing.com/ Quote Link to comment Share on other sites More sharing options...
Sorensin Posted October 18, 2009 Share Posted October 18, 2009 Completly stolen from another site but thought you guys might find some use in this. Ford 2.9 V6 24V Cosworth 1995 - 1998 Vented Mountings 4 Discs diameter 278.0mm Discs thickness 24.0mm Overall height 47.0mm Centre diameter 63.6mm Ford RS 2000 Cosworth 1995 - 2000 MK6 Vented Mountings 4 Discs diameter 260.0mm Discs thickness 24.0mm Overall height 43.8mm Centre diameter 63.6mm Minimum thickness 22.2mm Ford RS turbo 1986 -1990 Vented Mountings 4 Discs diameter 260.0mm Discs thickness 24.0mm Overall height 58.1mm Centre diameter 63.6mm Minimum thickness 22.8m Ford Puma 1.7 - 2000 onwards Vented Mountings 4 Discs diameter 258.0mm Discs thickness 22.0mm Overall height 43.5mm Centre diameter 63.6mm Minimum thickness 20.0mm Peugeot 307 2004 onwards HDI Vented Mountings 4 Discs Diameter 266.0mm Discs thickness 22.0mm Overall height 34.5mm Centre diameter 66.0mm Minimum thickness 20.0mm Ford 2.8i Capri Vented Disc Mountings 4 Studs 4 Disc diameter 245.0mm Disc thickness 20.0mm Overall height 32.0mm Hub hole diameter 68.3mm Peugeot 405 1988 - 1996 MI-16 4x4 Vented Mountings 4 Discs diameter 266.0mm Discs thickness 20.5mm Overall height 27.4mm Centre diameter 66.0mm Minimum thickness 18.5mm Quote Link to comment Share on other sites More sharing options...
