Low'N'Slow's FE3T Mk1 Escort
  • Replies 137
  • My name is Russell
    133
Aim is to have car done by October to race in SS2000 class
Thinking of getting 4 of these in 195 45 15" (wheels 15x8") thoughts?
http://www.federaltire.com/en/html/pdet ... ine=1&ID=1
Also looking for springs, these are the exact dimensions i require, is 175LB very heavy? i have about 8 set at the moment :oops: but they are all extremly stiff, need to get them all measured so i know what i have. what LB's should be aiming for? basicly when i h=just on them at the moment cant feel any movement. lol's
http://www.trademe.co.nz/Browse/Listing ... =276139572
ended up using counter sunk rivets in combination with sikaflex227. Broke rivet gun mid way through job, rushed out and brought a king-chrome and fuck me its amazing! allot better than those swivel head gymiky things.
Steelies is modifying/making my dump pipe for me, cheers heaps boe! im just dummying it up for the 2nd time to make sure my initial munted chop and weld up was correct. what you guys think, should be fine yeah? it clears everything inc gbox and the muff man should be able to sort out angles inc flexi pipe from there yeah?.
So trying to save so once thats done i can chuck it on the trailer and get a muffler system made.
just fixed the final flare on, removed and stripped painted the struts in prep for 25mm spacers arriving tomorrow.
Struts done!
- Gaz adjustable shocks
- Austin princess 4 pot calipers
- AP spacer kit
- 5 studd hubs
- capri vented disks
- braided break lines
- 450Lb track & 175Lb road springs
- keeper springs for WOF
Cheers to Jason for turning up the platform rings.
http://www.trademe.co.nz/Browse/Listing ... =278394995
Opps angles of picture is a bit odd, plated the pillar holes to meet race regs for fumes from the boot.
Recessed bonnet pins
Alloy door card
Window washer bottle
(will put the same alloy cover on the drivers side for the radiator catch tank so its all symmetrical.)
Slam panel
And my hero Nick aka MK1MAD sorting out my Mk2 loom
With the bonnet stays i welded the nut behind a massive washer as bellow so that the locking nut is hidden :)
Mounted strut brace and almost Finnish adding re enforcement to the bend on them.
New tow car :twisted:
New welder :twisted:
Battery lugs to be welded on once i get gas
Just stripped some wire i purchased and noticed it was silver instead of copper/gold does this mean its likely to be speaker wire?
Re fitted new kill switch to a more stable position, Cheers to UJ for the switch.
Its a fancy FIA job that kills the ignition coil/alternator, any suggestions on how to wire it up welcomed :mrgreen:
Not sure if to keep the old one killing something else but what?
Re ran the battery cable inside the sill which i was a bit worried about if the cable got pinched so now have an exterior kill switch also @ boot.
Nick has got the body wiring 95% done just need to sort out the wind wipers now, Made a bracket under the dash for re location of fuse box as the old one was directly next to the exhaust manifold and was worried if they were popping about not being practical to check.
extending all the wires to the correct length was a nights work.
Mounting the window washer nozzles and running the pipes from the pump
Polished the headlights chrome shrouds with auto soul and the indicator lenses with break cleaner which made them look better than new and painted a black edge around them as one was chrome the other not
:lol:
started setting up engine wiring
Wow its late
Made a bracket for the coils for a few reasons
1. So that standard leads can be used
2. to reduce interference by keeping the coils away from the CAS
3. reducing heat into the plenum like previously mounted.
Unfortunately as i was tightening one of the lock nut screws to on the coils (the one with they arrow) the bolt started spinning :twisted::x:(:cry: is it still usable anyone know? or anyone know were to get a new pack one from? i think they might be evo ones from mega distant memory.
Note mega bad tac's are the result no gas in welder
This ones for UJ to show I've learnt something. Oil temp,oil pressure, oil switch, water temp, volts & knock sensor. Just need to get thed cam belt checked over before I start her up again. Have not wired in alternator yet :doubt: have not worked out how to wire in the speedo yet either, will give the box a test thrashing first.
