Testament Posted August 2, 2008 Share Posted August 2, 2008 anyone done this to a race car? (UJ? vvega?) Need to do some on the 131 and looking for a few tips of the key places, Im guessing all around the front strut towers and where the guards join the firewall, and around the rear suspension mounting points. and also to fully weld or just intermittent e.g. 25mm weld 50mm gap 25mm weld etc. or whatever for reference Quote Link to comment Share on other sites More sharing options...
eskynut Posted August 2, 2008 Share Posted August 2, 2008 Basically weld in small bits and do every seam you can find. Quote Link to comment Share on other sites More sharing options...
Spencer Posted August 2, 2008 Share Posted August 2, 2008 yea take it easy most hard out race cars Ive seen are on a jig so they don't warp Quote Link to comment Share on other sites More sharing options...
Guest vvega Posted August 2, 2008 Share Posted August 2, 2008 not hard to turn a car into scrap if you do it wrong you only seam were you can gain the most benefit --- add gussets and spot/rossete weld them on rather than seam ..... i.e make triangles of key stress points in theory you can seam a whole car but you need to remember every bit of steel you melt will shrink as it cools so in essence a the right amount or welding is good....the wrong amount/places leads to stress fractures premature fatigue edit: just noticed in yoru pic were teh firewall meets the front chassi rail a gusset has all ready been welded in there i woudl have done them a bit bigger... but i dont know the free space you have ethier oh and drill holes in your gussets.......makes them lighter and you can keep a eye out for rust etc coat them in some rust retardent or buy a spot welder and trebble teh spot welds...... Quote Link to comment Share on other sites More sharing options...
Testament Posted August 2, 2008 Author Share Posted August 2, 2008 yeah those triangles aren't there as strengtheners - they were hiding more rust/holes not hard to turn a car into scrap if you do it wrongyou only seam were you can gain the most benefit --- add gussets and spot/rossete weld them on rather than seam ..... i.e make triangles of key stress points ok so dont go too crazy, I hears you, but also specifically what are usually the key areas? join between the firewall and the inner guards/floorpan? strut towers to inner guards etc. Quote Link to comment Share on other sites More sharing options...
Guest vvega Posted August 2, 2008 Share Posted August 2, 2008 yeah shame you haven't really got a decent firewall be good to hook a strut brase into that too chassis rail to strut /firewall weld all ya suspention mount points and transitions.... dont forget the back end your cage will stuffen up the middle ......thoug i would have made bigger base plates for it again all this is opinion and what i have done ... everyone has there own idea's Quote Link to comment Share on other sites More sharing options...
