fuel Posted April 3, 2008 Share Posted April 3, 2008 hey guys, I need to find a pair of struts suitable for taking the threaded top off to weld to my shortened struts, which are about 55mm OD. So I need to find struts which have a similar OD size, and has removable inserts - doesn't matter if it's front or rear. Cheers! Quote Link to comment Share on other sites More sharing options...
Ke36 Posted April 3, 2008 Share Posted April 3, 2008 if it helps mate my starion coilovers have camry struts in them think there out of a v6 model Quote Link to comment Share on other sites More sharing options...
fuel Posted April 3, 2008 Author Share Posted April 3, 2008 I'm all sorted for the front boe am using starion inserts which will be shortened, they have plenty of stroke. It's the rears which I'm having trouble with, because they are a sealed unit I can't just whack any insert in and put the nut back on - I need to find a strut with the same or similar OD I can chop the tops off so I'll have a threaded section and a nut to capture the inserts. I could use Starion front struts as they are the same OD, but I'm a bit hesitant to chop up a pair of them... You dig? Quote Link to comment Share on other sites More sharing options...
Toucan Posted April 3, 2008 Share Posted April 3, 2008 Will give them a measure when I get home Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted April 3, 2008 Share Posted April 3, 2008 DELETED Quote Link to comment Share on other sites More sharing options...
fuel Posted April 3, 2008 Author Share Posted April 3, 2008 Thanks Callum I didn't realise such a thing existed - I'll see if Stocks has them as that's where I'm getting my threaded sleeves from. Cheers Quote Link to comment Share on other sites More sharing options...
