d.p.n.s Posted January 1, 2008 Share Posted January 1, 2008 hi all one of my strut tops is stuck on i clamped the springs and undune the top nut and it wouldnt come off ive relesed the spring and that wont push it off ive used hea,wd40,FBH, and the fuking thing is still there. the other one came off straght away. any ideas p.s its like a time bomb at the moment sitting in my garge with no nut on it and a unclamped spring just waithing to go off Quote Link to comment Share on other sites More sharing options...
QCADTA Posted January 1, 2008 Share Posted January 1, 2008 If your replacing the insert smack the shit out of it with a hammer and a pin punch, or if thats to brutal grab a bearing puller and get it that way. I had the same problem with mine. theres not that much tension on the spring when it does pop off. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted January 1, 2008 Author Share Posted January 1, 2008 If your replacing the insert smack the shit out of it with a hammer and a pin punch, or if thats to brutal grab a bearing puller and get it that way. I had the same problem with mine. theres not that much tension on the spring when it does pop off. all im doing is changing the tops to mk1 tops. i thing a bearing puller is going to be the way or ill just carry on belting shit out of the top till it comes off but its alwasy the way ones so easy and the other takes hours. dan Quote Link to comment Share on other sites More sharing options...
Gaz Posted January 2, 2008 Share Posted January 2, 2008 Wind nut on two turns then bolt tophat back in car and then hit the top. Itll come out pretty easy... I had exact same problem when I did Bizzos and my last resort was this.. One hit and it came off... after hours of fucking round with CRC etc, Quote Link to comment Share on other sites More sharing options...
sholdowa Posted January 2, 2008 Share Posted January 2, 2008 Yup, wot Gaz said. Hit along the axis of the shock Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted January 2, 2008 Author Share Posted January 2, 2008 all done guys got home after a hard days work was fuked off with a customer saved that up till i got home when in to the garge and just fukin hit !!!!! and it came off hahaha Quote Link to comment Share on other sites More sharing options...
