Scrubb Posted April 30, 2007 Share Posted April 30, 2007 Hey just got head reconditioned and new waterpump and radiator fixed and in the process I think the distrubitor or something got moved and the marks that were put on it dissapeared or something. I think its getting the timing done on wed.. anyone know what the correct timing settings are for my 4G32 in me EX? Talked to Caboonatlarge and he said he thinks it would be about 5 degrees? I dont know anything about ignition timing so any help will be appreciated Quote Link to comment Share on other sites More sharing options...
lowlancer Posted April 30, 2007 Share Posted April 30, 2007 yeah 5 or 8 Quote Link to comment Share on other sites More sharing options...
Scrubb Posted May 1, 2007 Author Share Posted May 1, 2007 Its not going at all atm.. think distributer is out.. what do I do there? Quote Link to comment Share on other sites More sharing options...
lowlancer Posted May 1, 2007 Share Posted May 1, 2007 What's it doing? Backfiring? Probably dizzy out 180 degrees, try spinning cap round to the opposite side and trying again Check spark with timing light/screwdriver arcing, and smell for fuel too Long as they're there, you should be ok Timing=probably what the prob is Quote Link to comment Share on other sites More sharing options...
Scrubb Posted May 1, 2007 Author Share Posted May 1, 2007 Its not doing anything lol Just turns over and over and over and can smell fuel.. I'm sure its sparking and everything. I think someone's gonna do something with timing light tomorrow.. I know nothing lol Quote Link to comment Share on other sites More sharing options...
lowlancer Posted May 1, 2007 Share Posted May 1, 2007 Stick a screwdriver in one of the sparkplug leads, and lie it so that the shaft of the screwdriver is just above a ground source like a bolt on the car body. I use the bolts from the suspension coming through the body by the engine. Then crank car and see if a spark is arcing from screwdriver to body If not, do the same with lead from coil to distributor If it is arcing, your distributor isn't working right, if it isn't, your coil is stuffed or wired wrong. Also, check plugs. Might be fouled or stuffed. Quote Link to comment Share on other sites More sharing options...
Scrubb Posted May 1, 2007 Author Share Posted May 1, 2007 Will let whoever is having a look tomorow know.. thank you Quote Link to comment Share on other sites More sharing options...
Ogre Posted May 1, 2007 Share Posted May 1, 2007 The GSR engine is rated for 12 degrees running premium octane also.... Quote Link to comment Share on other sites More sharing options...
lowlancer Posted May 1, 2007 Share Posted May 1, 2007 GSR? As in LA-LC GSR? Doubt he'd have that one mang, tis an ex. Even a GSR EX uses the 1800 Quote Link to comment Share on other sites More sharing options...
Scrubb Posted May 1, 2007 Author Share Posted May 1, 2007 nah, its just an EX GSL, not a GSR Quote Link to comment Share on other sites More sharing options...
Ogre Posted May 1, 2007 Share Posted May 1, 2007 i was talking the GSR1600 EX lancer, its rated at 12degrees on 95 octane.Im running the g63 at 12degrees atm, mite put more into it and see what happens. Quote Link to comment Share on other sites More sharing options...
