corrupt Posted April 27, 2007 Author Share Posted April 27, 2007 problem still to be fixed, this weekend will be when that happens, when i got more than an hour of daylight to fix and appco/repco are open and have the brushes in stock etc... i did retard the timing back to the standard 8btdc and it did help, but did not solve the problem.... Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted April 27, 2007 Share Posted April 27, 2007 probly the contacts in the starter, if worn out the starter solinold will click open but wont touch the contacts together - easyfix tho. can test by by passing the solinold and if motor spins sweet thats ya prob Quote Link to comment Share on other sites More sharing options...
corrupt Posted April 28, 2007 Author Share Posted April 28, 2007 went to appco this morning, guy couldnt get the right part code for the brushes/looked for 20mins in numerous parts cataloges, useless. just gonna replace the whole starter now, seems the easiest option Quote Link to comment Share on other sites More sharing options...
corrupt Posted April 28, 2007 Author Share Posted April 28, 2007 on removal of the old starter motor i noticed it looks pretty fucked. the bendix gear? was pretty loose on the shaft, there was a loose ring/washer on the shaft which looks like it has come loose from where the shaft mounts at the end, and there was also a half cirlce ring thing which looks to have broken off something, maybe a circlip or something. oh well, put in a starter i found in the garage and its all sweet now, its a pretty noisey starter motor but Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted April 28, 2007 Share Posted April 28, 2007 its a pretty noisey starter motor but But now you have a starter you can rebuild at your leasure while supping down a cold one.... or 5 Quote Link to comment Share on other sites More sharing options...
corrupt Posted April 28, 2007 Author Share Posted April 28, 2007 its a pretty noisey starter motor but But now you have a starter you can rebuild at your leasure while supping down a cold one.... or 5 good point there....dunno why im even fixing the cortina, should be getting the scrot a wof so the tina can come off the road for upgrades, really gotta get off my ass and fix the rust. Quote Link to comment Share on other sites More sharing options...
