Gaz Posted July 26, 2006 Share Posted July 26, 2006 Found it. A-Head Cylinder Head Specialists Ltd Address: 71 A Riri St Rotorua Phone number: 0-7-349 4212 Im sure it used to be called A-1. Quote Link to comment Share on other sites More sharing options...
2FKNLO Posted July 26, 2006 Author Share Posted July 26, 2006 A mate did some and the rest at A1 head specilist in Rotorua. I dont recomend them at all tho.You may need lash caps. Without them you will have to have the tappets wound to far up meaning fark all adjustment and aparently its not good. Plus will make the clearances fucked up to get right. those lash caps sorta extend the valve stem length aye? think i remember readin about them in my "how to power tune ford sohc" pdf Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 26, 2006 Share Posted July 26, 2006 Yeap thats what they do. They arnt needed in the 2l heads. You can go without as I supose most amatures would. I think you need to send me that .pdf ..... please. Quote Link to comment Share on other sites More sharing options...
2FKNLO Posted July 26, 2006 Author Share Posted July 26, 2006 just gonna run it with std carb for now aye Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 26, 2006 Share Posted July 26, 2006 just gonna run it with std carb for now aye Thats what I am doing. Rejetted. I also have a single 45 I and am trying to source a single 45 manifold at the mo. That should be a slightly better carb without using too much extra gas like twin 45s would. Quote Link to comment Share on other sites More sharing options...
2FKNLO Posted July 26, 2006 Author Share Posted July 26, 2006 ive changed the idle jets(think thats what they are the ones on the sides) to 50 primarys 60 secondarys. is that what u done or do i need to do more? Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 26, 2006 Share Posted July 26, 2006 Im not sure what im going to run yet. Carb is still standard at the mo. Quote Link to comment Share on other sites More sharing options...
2FKNLO Posted July 26, 2006 Author Share Posted July 26, 2006 Yeap thats what they do. They arnt needed in the 2l heads. You can go without as I supose most amatures would. I think you need to send me that .pdf ..... please. yeah man ill send it when im in tokoroa again. forgot to bring my cds when i moved up to hamilton.. Quote Link to comment Share on other sites More sharing options...
2FKNLO Posted July 26, 2006 Author Share Posted July 26, 2006 oh and have you got a lightened flywheel ? Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 26, 2006 Share Posted July 26, 2006 oh and have you got a lightened flywheel ? had one, didnt use it. it looked too light. Plus its a light car anyway so dont really need one. Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 26, 2006 Share Posted July 26, 2006 Yeap thats what they do. They arnt needed in the 2l heads. You can go without as I supose most amatures would. I think you need to send me that .pdf ..... please. yeah man ill send it when im in tokoroa again. forgot to bring my cds when i moved up to hamilton.. Sweet, cheers man. Quote Link to comment Share on other sites More sharing options...
2FKNLO Posted July 26, 2006 Author Share Posted July 26, 2006 thinkin bout the 2.3 v6 carb but need to find one first Quote Link to comment Share on other sites More sharing options...
RT Posted July 28, 2006 Share Posted July 28, 2006 you do need lash caps on the 2L if the cam has big lift.. Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 28, 2006 Share Posted July 28, 2006 thinkin bout the 2.3 v6 carb but need to find one first I have a few carbs im going to try through to see which is better, a 32/36 rejetted, a 40/40 and a single 45. Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 28, 2006 Share Posted July 28, 2006 you do need lash caps on the 2L if the cam has big lift.. Sweet, What do we call a big lift cam? Quote Link to comment Share on other sites More sharing options...
RT Posted July 28, 2006 Share Posted July 28, 2006 anything bigger than a fast road cam should use lash caps, can't remember the specs as I haven't used a big cam for years. Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 30, 2006 Share Posted July 30, 2006 anything bigger than a fast road cam should use lash caps, can't remember the specs as I haven't used a big cam for years. Oh so basically if your building a race engine. Those cams are pretty shocking on road from what ive heard. Did you used to run one on the road RT? Quote Link to comment Share on other sites More sharing options...
RT Posted July 30, 2006 Share Posted July 30, 2006 mine wasn't a full race cam.. back then they called them 3/4 race cams. It had 300degress of duration and I think 280 lift or something I can't remember the specs. yeah I ran it on the road. It idled at 2000rpm and sounded like a tractor. It also lost power down low.. but sounded grunty as when you put your foot down and loved the highway. ah.. what fun. It poured through the gas! he heh Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 31, 2006 Share Posted July 31, 2006 Sounds a mission to drive with. Hope mines not that bad. Mines 285 duration and 274 lift. Quote Link to comment Share on other sites More sharing options...
RT Posted July 31, 2006 Share Posted July 31, 2006 yours will be similar I'm guessing.. but not as bad. You'll be right. mine was a daily driver back then so it was a bit of a pig at times.. Quote Link to comment Share on other sites More sharing options...
