2FKNLO Posted July 25, 2006 Share Posted July 25, 2006 got a fast road cam and like wondering if i would nead to use heavy duty single valve springs or just use new standard ones? what you fallaz rekon Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 25, 2006 Share Posted July 25, 2006 Dont use heavy valve springs in a pinto full stop. itll eat cams like no 2moro. Quote Link to comment Share on other sites More sharing options...
2FKNLO Posted July 25, 2006 Author Share Posted July 25, 2006 ok thanks dude. use new standard ones. would anyone know prices of them by any chance? and another question bout the 2L with 1600 head. does porting drop compression? ive given my 1600 a light port(taken out sharp edges etc) gonna chuk it on 2L 205 block with the fast road cam Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 25, 2006 Share Posted July 25, 2006 Why use new ones. I rebuilt my head and used the standard ones. They usually pretty sweet. New is always good tho I supose. What I did to my 1600 head... -Enlarged the exhaust valves to use 2.0litre valves -Replaced the cam bearings -Removed material from the combustion chamber (this is what drops the compression) -You will want to use lash caps as the valves will be too short. -Smoothed of the sharp edges etc but tried not to go to radical as it is very possiable to fuck it up with pinto heads -Adjustable cam gear to set the timing to suit the re-profiled high lift cam shaft -um, refaced the lifters to match the cam grind I got. thats bout it. For the combustion chamber you want to take 3ccs off each chamber and this will take ya compression ratio to about 10.9:1. Will prob need to run 98 fuel to stop detonation. Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 25, 2006 Share Posted July 25, 2006 Oh yeah and I wouldnt even bother putting the 1600 head on unless you have done at least something to the compression chambers. Otherwise the 205 block wont last long at all... thats if you can get it tuned right without our fav lil friend Avgas Quote Link to comment Share on other sites More sharing options...
2FKNLO Posted July 26, 2006 Author Share Posted July 26, 2006 oh what that sux then. did you remove do the work to drop your compression or did a shop? and did you replace the camshaft bearings yourself as well? just wondering if i could have a go at it. ive got new cam bearings and lifters that come to suit the cam grind. Quote Link to comment Share on other sites More sharing options...
2FKNLO Posted July 26, 2006 Author Share Posted July 26, 2006 had a look at the valves in it and theyre the same size as 2L ones too Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 26, 2006 Share Posted July 26, 2006 had a look at the valves in it and theyre the same size as 2L ones too Are you sure..? They shouldnt be? Quote Link to comment Share on other sites More sharing options...
2FKNLO Posted July 26, 2006 Author Share Posted July 26, 2006 yeah man suprised me too Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 26, 2006 Share Posted July 26, 2006 yeah man suprised me too One less thing to do then which is awsome. Has it already been on a car or have you not run it before? Is it running Lash caps? Sounds like youll have very similar engine to mine. Remember youll need to rejet the carb to suit also to get the most out of it. Quote Link to comment Share on other sites More sharing options...
2FKNLO Posted July 26, 2006 Author Share Posted July 26, 2006 have had it running but only when it was with the 1600 block. doesnt have lash caps. whered u get the work done to your head? Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 26, 2006 Share Posted July 26, 2006 A mate did some and the rest at A1 head specilist in Rotorua. I dont recomend them at all tho. You may need lash caps. Without them you will have to have the tappets wound to far up meaning fark all adjustment and aparently its not good. Plus will make the clearances fucked up to get right. Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 26, 2006 Share Posted July 26, 2006 Also you may need a geared starter motor to turn it over easier. Especially if ya bat is n boot. This is the one I got which works sweet. http://www.trademe.co.nz/Browse/Listing ... d=63916250 But it needs some slight re wiring as it is NOT plug and play like he states. Quote Link to comment Share on other sites More sharing options...
2FKNLO Posted July 26, 2006 Author Share Posted July 26, 2006 bah yeah nasty ol tokoroa dont have places to get that shit done. anyone know a good place in ham town to get sum stuff done for got prices? damn Quote Link to comment Share on other sites More sharing options...
2FKNLO Posted July 26, 2006 Author Share Posted July 26, 2006 good prices i mean fark Quote Link to comment Share on other sites More sharing options...
2FKNLO Posted July 26, 2006 Author Share Posted July 26, 2006 was thinkin about buying one of them too. is it easy wiring it up in there? Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 26, 2006 Share Posted July 26, 2006 bah yeah nasty ol tokoroa dont have places to get that shit done. anyone know a good place in ham town to get sum stuff done for got prices? damn Im from Rotorua. That A1 place is in Rotorua. They pretty shit tho. Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 26, 2006 Share Posted July 26, 2006 was thinkin about buying one of them too. is it easy wiring it up in there? Yeap, basically bolt on. Just have to do a bit of rewiring because as they are they dont return the 12v to coil when you turn key. I can explain how to rewire if you need. Quote Link to comment Share on other sites More sharing options...
2FKNLO Posted July 26, 2006 Author Share Posted July 26, 2006 whats the details for that A1 place? yeah im pretty sure ill be getting one of them starters dont want to go through batteries or fuck up anything else. Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 26, 2006 Share Posted July 26, 2006 I cant find any info on A1. Its called "A1 cylinder head specilists" Maybe they went out of buisness or sumthng. They are pretty useless cunts. Also the starter motors sound mean. Real grunty. What carbs ya going to run? Quote Link to comment Share on other sites More sharing options...
