davidian Posted January 23, 2006 Share Posted January 23, 2006 ok since ive got my engine back its got this funny engine rattle when i put my foot down, so its not there when just cruising... sounds like theres a fuckin ball bearing bouncing around the inside... i thought it was pinging from shit gas so i filled up the tank and used +10 unit octane boost as well as lead substitute but still no luck. the guy that rebuild it set the timing to std. escort 1600 and told me to call the guy who initially built the engine and ask him what exactly the timing should be. i havent been able to get a hold of the guy. anyways im wondering if this is a timing issue or wtf?? any ideas? thanks Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted January 24, 2006 Share Posted January 24, 2006 sounds like detonation hard. but you'd think running better fuel would sort it out? hasn't got a poorly sealing exh manifold gasket per chance? retard the timing a little and try that? not running lean? Quote Link to comment Share on other sites More sharing options...
davidian Posted January 24, 2006 Author Share Posted January 24, 2006 good call cuz, ill check the exhaust as it does sound noisier these days... just like back in the days of loose extractors i dont think its running lean as it usually reaks of gas... ill try retarding the timing as soon as this fucking rain eases up Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted January 24, 2006 Share Posted January 24, 2006 good call cuz, ill check the exhaust as it does sound noisier these days... just like back in the days of loose extractors i dont think its running lean as it usually reaks of gas... ill try retarding the timing as soon as this fucking rain eases up yuh. from what i would have thought, mega rich stz would cancel out detonation of that degree... meh. might only run rich on idle tho? i duno Quote Link to comment Share on other sites More sharing options...
Chrome_GT Posted January 26, 2006 Share Posted January 26, 2006 Any chance the metal ring in the exhaust flange has cracked in half and fallen down the exhaust downpipe? Weird suggestion but possible. Myne had that problem and it the broken off part rattled around for a while. Quote Link to comment Share on other sites More sharing options...
davidian Posted January 26, 2006 Author Share Posted January 26, 2006 when you boot it it kinda sounds like its in too high a gear if you know what i mean anywhoo, booked in for a dyno tune next wednesday.. $130 a hour. ouch Quote Link to comment Share on other sites More sharing options...
Chrome_GT Posted January 26, 2006 Share Posted January 26, 2006 Weird. Yeah it really sounds like detonation. Have you tried just turning the dizzy to change the timing. Make a mark with a nail or something so you can turn it back to where it was if there is no improvement. What mods were done to the engine? Quote Link to comment Share on other sites More sharing options...
Hemi Posted January 26, 2006 Share Posted January 26, 2006 thats got me confused , id say detonation like everyone else but yes dont seem to be that :S, could be something in the exhaust i had a ratlle on acceration once and a week later my exhaust fell in half ...just a suggestion Quote Link to comment Share on other sites More sharing options...
fuel Posted January 26, 2006 Share Posted January 26, 2006 That does sound like detonation. Has your distributor got vacuum advance? Make sure the advancing mechanism isn't stuck or fouled. Retard the timing, and see if it does it again. BTW, when octane boosters say up to 10 points, 1 point equals 0.1 RON. If you put 95 in it, it would most likely have upped it to 96. Quote Link to comment Share on other sites More sharing options...
Hemi Posted January 26, 2006 Share Posted January 26, 2006 yea well i dont get that cos i run my 1600 on 96 with plugs that were 2 points too hot (rebuilt motor) witha total of something like 45 degrees advance and it was only ment to be 35 at most or sumthing and my car ddnt detonate .... Quote Link to comment Share on other sites More sharing options...
davidian Posted January 26, 2006 Author Share Posted January 26, 2006 That does sound like detonation. Has your distributor got vacuum advance? Make sure the advancing mechanism isn't stuck or fouled.Retard the timing, and see if it does it again. BTW, when octane boosters say up to 10 points, 1 point equals 0.1 RON. If you put 95 in it, it would most likely have upped it to 96. yeah well i filled it up with 98 and the booster i put in was the highest rated one i found to buy. compared about 3 of them off the shelf. the guy that built my motor initially said not to run it on anything less than 98, pref higher... never did ask what the compression was. hopefully all will sort out next week with the dyno tune and hopefully i find out what the car is putting out as well... What mods were done to the engine? in brief... 60 thou oversize pistons pocketed, 2L valves, formula ford double valve springs, cam grind, 32/36 etc Quote Link to comment Share on other sites More sharing options...
