esky boi Posted December 6, 2005 Share Posted December 6, 2005 Im getting the electronic ignition setup off a sierra.. when fitting the dizzy how can I get a static ignition timing setting to at least start and drive the car where I can get the timing set properly with a timing light?? Like with points you can just use the old lightbulb trick.. is there anything like this you can do to set up the electronic dizzy or is it just a matter of guessing? Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted December 6, 2005 Share Posted December 6, 2005 the middle is always good for me then i adjust it by ear see if the revs go up ot down etc.... don't forget that need a matching coil for electonic dissys Quote Link to comment Share on other sites More sharing options...
esky boi Posted December 6, 2005 Author Share Posted December 6, 2005 Yea man, got a coil for it as well. Hmm I think I know what u mean by the middle.. but Sierras dont have that little slot with the bolt going through it on the head where you can centre it and twist either way like most newer cars. Its just bolted to the block with a little clamp thing, sorta hard to explain, but yea Quote Link to comment Share on other sites More sharing options...
Jonny Posted December 6, 2005 Share Posted December 6, 2005 PM Kris he sets up a lot of electronic ignition on old fords. Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted December 6, 2005 Share Posted December 6, 2005 Yea man, got a coil for it as well. Hmm I think I know what u mean by the middle.. but Sierras dont have that little slot with the bolt going through it on the head where you can centre it and twist either way like most newer cars. Its just bolted to the block with a little clamp thing, sorta hard to explain, but yea o... my bad, i guess u'll have to buy a timing light or do it by ear, what i'd do is take note of excatly where the rotor was pointing compared to the cap (on old dissy) and copy that for start-up purposes. Quote Link to comment Share on other sites More sharing options...
excort Posted December 27, 2005 Share Posted December 27, 2005 hey i see you's seem to know how to wire up the dizzy im trying to put one off a 88 sierra in my escort with a 2ltr in it im wondering if the wireing diagram i have got here is gona work with what ive got i beilive thats for wireing up the older dizzy found in 84 model sierra's but could i use the control box from that on my newer dizzy ?? thanks any info would be apreciated Quote Link to comment Share on other sites More sharing options...
SYKOV6 Posted December 29, 2005 Share Posted December 29, 2005 that looks pretty easy just check if the later model wiring is the same colours if it is then go hard. would prolly pay not to mix early and late model parts together though Quote Link to comment Share on other sites More sharing options...
excort Posted December 29, 2005 Share Posted December 29, 2005 yeah ay well ive got wireing diagrams of the newer sierra and i have the control box that goes with my dizzy so im gona have a go at wireing it up ive cut the wireing loom out and im gona trace all the wires to the coil/dizzypower etc bak and make a second loom should work i hope Quote Link to comment Share on other sites More sharing options...
esky boi Posted January 2, 2006 Author Share Posted January 2, 2006 Still havn't got round to setting mine up.. Excort would you be able to chuck up a pic of the newer setup.. pretty sure thats what mine must be because the wires on the diagram above are slightly different colours to what I have aye. Quote Link to comment Share on other sites More sharing options...
excort Posted January 3, 2006 Share Posted January 3, 2006 yeah man i put a tech article up Quote Link to comment Share on other sites More sharing options...
