davidian Posted August 22, 2005 Share Posted August 22, 2005 ok what im wondering is how long can you run your car for on a blown water pump untill you do major damage to the motor? wasw driving the car in the weekend when it started spluttering and missing like a really bad fuel mixture or timing waaay out or something, ran like that for about 150-200m before slowing itself down to a stop. pulled the pump off as it was pissing water/antifreeze out of either the pump or the gasket between the pump and block. also, is there a way to chek the water pump? it seems fine and less than year old, but is there a def way of cheking? ta Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted August 22, 2005 Share Posted August 22, 2005 water pumps are driven off the engine so yeah- only thing that will cause damage to and engine through a water pump is if the water is pissing out so much as to runout, or not be pumped around the galleries, therefore overheating it. Mini survived for more than a year before I bothered buying a new one, so long as you keep tabs on the water level, and temp level then you'll be sweet. Quote Link to comment Share on other sites More sharing options...
davidian Posted August 22, 2005 Author Share Posted August 22, 2005 um well its all apart now, no way im putting that pump back in till i at least chek it. damn temp gage (sp?) dont work so i got no idea. but she wasnt overcooking, just sorta gradually lost power over 200m stretch and stopped. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted August 22, 2005 Share Posted August 22, 2005 that's random as.... i wouldnt have thought that it would stop unless it cooked hard only way of checking is looking for water stains coming out the seal/bearing vent hole by the pulley, or around the shaft, and lso the bearing - whether it's noisy or worn (shaft play etc) Quote Link to comment Share on other sites More sharing options...
peteretep Posted August 22, 2005 Share Posted August 22, 2005 you should get your temp gauge working as it is rather important Quote Link to comment Share on other sites More sharing options...
DavidTheCreator Posted August 22, 2005 Share Posted August 22, 2005 as long as u want ...until of course the bearing complelty shits itsefl and u see the gauge go from norm to HOT in about 10 seconds .....that happened to me i ran the esky for 10 min after the water ran out ...admittidly the engine was just about on fire but its started up after that ....so to be honest fix it ..it cost between $50 to $100 to get it done and can save u big bucks from a warped head or such ...just my input mongol Quote Link to comment Share on other sites More sharing options...
davidian Posted August 22, 2005 Author Share Posted August 22, 2005 hmm true yeah i will fix it. went to repco and some old cunt started giving me a lecture , he's like "we got 2 types, one is $90 and the other is $180. yours is likely to be the $90 one but no repco in the country stocks them, you should go to Autoclutch and get one as they deal with old and obsolete pumps" ? "muthafuka youre the obsolete one round here" Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted August 22, 2005 Share Posted August 22, 2005 haha, yeah repco sucks cock. ring sparkle he'll get you one I'm sure Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted August 22, 2005 Share Posted August 22, 2005 ivan isnt that the same for all eksie parsts... wat about when we went to get a bearing for ur car a while ago? Quote Link to comment Share on other sites More sharing options...
davidian Posted August 22, 2005 Author Share Posted August 22, 2005 oh lord...... the incompetency man i went to fill up at the local gundy gassie the other day and the dude's like"hey what sorta car is that?"... "umm mk1 ford escort". "oh ok, but what model is it?" Quote Link to comment Share on other sites More sharing options...
Ned Posted August 22, 2005 Share Posted August 22, 2005 drive up to appco in henderson man, those guys are way better then repco Quote Link to comment Share on other sites More sharing options...
DavidTheCreator Posted August 23, 2005 Share Posted August 23, 2005 your fukin joking me right , thats bullshit i used to work at supercheap as the parts manager in roto's and the bloody pump cost $50 , and before anyone says anything its for ..1300 1600 AND some series of 2ltr ... that repco guy needs to retire Quote Link to comment Share on other sites More sharing options...
