Guest Scheme Posted August 21, 2005 Share Posted August 21, 2005 Does anyone know how to get the front windscreen off? I dont really wanna go ripping at it without knowing.. Quote Link to comment Share on other sites More sharing options...
Gaz Posted August 21, 2005 Share Posted August 21, 2005 Use a peice of wire around the window while two people sit in the front seats with feet on window pushing a bit Quote Link to comment Share on other sites More sharing options...
Bistro Posted August 21, 2005 Share Posted August 21, 2005 Once the locking strip is out as Methodz said get a couple people in there. remember push with equal distrobutions. Make sure someone is there to catch the windscreen. There may also be a strip on the inside. Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted August 21, 2005 Share Posted August 21, 2005 yeah becareful as they can crack if to much pressure is put on one side what about to put them back in? Quote Link to comment Share on other sites More sharing options...
Bistro Posted August 22, 2005 Share Posted August 22, 2005 Putting them back in is a bit of a cunt. You have to wigle it round and there will always be the last courner that will be a mish. If you're getting new seals and stuff take get a window place to do it as they will guarantee it and they also have the little tool to put the locking strip back in. Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted August 22, 2005 Share Posted August 22, 2005 u know what they charge? Quote Link to comment Share on other sites More sharing options...
Gaz Posted August 22, 2005 Share Posted August 22, 2005 around 80$ from memory. Quote Link to comment Share on other sites More sharing options...
FunkmasterTed Posted August 22, 2005 Share Posted August 22, 2005 if u don't want the windscreen an its a rubber fit window u put both feet on windscreen from inside, then push, get a long screw driver an work the leg of the rubber off the body, if its a urethaned window justcut from inside with stanley knife put mild pressure on and u will feel the pressure release as u work ur way around. its a bit of a cunt without the right tools, would do it 4 u if u were in the hbay as im a glazier Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted August 22, 2005 Share Posted August 22, 2005 if u don't want the windscreen an its a rubber fit window u put both feet on windscreen from inside, then push, get a long screw driver an work the leg of the rubber off the body, if its a urethaned window justcut from inside with stanley knife put mild pressure on and u will feel the pressure release as u work ur way around. its a bit of a cunt without the right tools, would do it 4 u if u were in the hbay as im a glazier u cumin up to aucks any time soon Quote Link to comment Share on other sites More sharing options...
Ned Posted August 22, 2005 Share Posted August 22, 2005 i took my windows out with a screw driver... i had no interiour so no1 could sit down and reach the window i told you how to put it back in logan... or have you still not tried Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted August 22, 2005 Share Posted August 22, 2005 im gonna get it done by the pros that way tehre is a warrenty Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted August 23, 2005 Share Posted August 23, 2005 yeah smith and smith warrenty it fo lyfe (fo real) Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted August 23, 2005 Share Posted August 23, 2005 yeah isnt that teh ad on tv? Quote Link to comment Share on other sites More sharing options...
Ned Posted August 24, 2005 Share Posted August 24, 2005 yeah. with the old dude. got his window replaced in 1967 or some shit Quote Link to comment Share on other sites More sharing options...
SYKOV6 Posted August 26, 2005 Share Posted August 26, 2005 if u don't want the windscreen an its a rubber fit window u put both feet on windscreen from inside, then push, get a long screw driver an work the leg of the rubber off the body, if its a urethaned window justcut from inside with stanley knife put mild pressure on and u will feel the pressure release as u work ur way around. its a bit of a cunt without the right tools, would do it 4 u if u were in the hbay as im a glazier who do ya work for dude? Quote Link to comment Share on other sites More sharing options...
FunkmasterTed Posted August 27, 2005 Share Posted August 27, 2005 napier glass, 2nd year apprentice Quote Link to comment Share on other sites More sharing options...
