peteretep Posted July 24, 2005 Share Posted July 24, 2005 i have a standard 1300 engine but when the engine is cold and you put on the gas it has a distinctive clicking sound and it almost stalls the engine(very rarely it does), my boss told me that it may be a broken distributor or sometihng like that. sometimes all you just have to tap the gas and it does it but other times you just have to accelerate really slowly to avoid it. also when i put the pedal to the metal all the car does it sound drowned before slowly accelerating again, im not sure what this is...this occurs even when the engine is warm. thanks Quote Link to comment Share on other sites More sharing options...
esky boi Posted July 24, 2005 Share Posted July 24, 2005 Not sure about the stalling. But do you have a 2 barrel carb? I had a similar problem with the drowning sound, could be something different but.. I found that the jet inside the secondary barrel of the carb had come loose and had moved round so that the hole was pointing upwards instead of down towards the throttle butterfly. So at full throttle it was just opening wide, letting heaps of air through and hardly any petrol. Quote Link to comment Share on other sites More sharing options...
peteretep Posted July 24, 2005 Author Share Posted July 24, 2005 nah i dont have a 2l carb and ive had a little play around with the carb but that seems to be working fine, of course my car still doesnt like idling when its cold but otherwise seems ok Quote Link to comment Share on other sites More sharing options...
rs2000escort Posted July 25, 2005 Share Posted July 25, 2005 there just old cars lol my brown escort did it aswell still does only did it when it was cold never when work duno why but yeh my mazda does it aswell i think it is just a carb thing ay might need cleaning or something Quote Link to comment Share on other sites More sharing options...
Guest jomojojo Posted August 10, 2005 Share Posted August 10, 2005 Most likely your carburettor needs some attention. Goto a local specialist and have them recon the carb then tune it on the car. Pity your not in welly or you could bring it into work and i'd do it for you. Check your points and distributor cap for cracks or moisture also. Sparkplugs ok? Try rule the cheap things out first as carb recons are expensive. Quote Link to comment Share on other sites More sharing options...
peteretep Posted August 10, 2005 Author Share Posted August 10, 2005 well i found my vacuum advance almost isnt working at all so that explains alot Quote Link to comment Share on other sites More sharing options...
Defcon Posted August 10, 2005 Share Posted August 10, 2005 Yeah i was guna say sounds like timing/ points.Maybee time for a new set of points or to set the gap again. Def' Quote Link to comment Share on other sites More sharing options...
peteretep Posted August 10, 2005 Author Share Posted August 10, 2005 yea i need to replace those too but hopefully it will last until i get an electronic ignition Quote Link to comment Share on other sites More sharing options...
Guest Eddie W Posted August 10, 2005 Share Posted August 10, 2005 Could be a blocked pump jet as well. Quote Link to comment Share on other sites More sharing options...
peteretep Posted August 10, 2005 Author Share Posted August 10, 2005 fuel pump? well i just got a done up 1600, do you think a standard fuel pump will pump enough or do you reckon i should get an uprated one. The guy who i bought it off was running an uprated one so the hole where the standard pump goes has a plate covering it Quote Link to comment Share on other sites More sharing options...
