Guest vhpacer73 Posted July 17, 2005 Share Posted July 17, 2005 Would a 2 litre from a mk4 cortina bolt straight into a mk1 esky if you use the mounts and crossmember from the cortina? Link to comment Share on other sites More sharing options...
peteretep Posted July 17, 2005 Share Posted July 17, 2005 no. takes some work Link to comment Share on other sites More sharing options...
esky boi Posted July 17, 2005 Share Posted July 17, 2005 Should be the same as a MK2 so the answer is yep it will... The mounts line straight up, and it will bolt to the 1300/1600 gearbox no prob - will bolt straight up to a 5 spd Sierra box too, but fitting the 5 spd box to the car takes abit of work its worth it tho. But with the intake, exhaust dizzy and alternator (and a couple of other things - cant remember exactly what right now) being on the opposide sides to the X-flow it makes things a little interesting... It takes abit of work, but can be done. Ive just about finished doing the 2 litre, 5speed conversion to a mk2 right now, so I can give you a bit of info... Theres a few others on here that have also done it or are in the process of doing it so yea..... Link to comment Share on other sites More sharing options...
davidian Posted July 17, 2005 Share Posted July 17, 2005 search around.. covered many times from driveshafts to breaks to re-routing lines etc. Link to comment Share on other sites More sharing options...
Guest dreadedretard Posted July 18, 2005 Share Posted July 18, 2005 not this topic again.. lol Link to comment Share on other sites More sharing options...
peteretep Posted July 18, 2005 Share Posted July 18, 2005 someone write up a tech article about how to do it then if its so common Link to comment Share on other sites More sharing options...
Ned Posted July 18, 2005 Share Posted July 18, 2005 not this topic again.. lol fair enough man Link to comment Share on other sites More sharing options...
esky boi Posted July 18, 2005 Share Posted July 18, 2005 davidian wrote: search around.. covered many times from driveshafts to breaks to re-routing lines etc. mm, tru dat. Take a look back a few pages, theres quite abit thats been covered in a few topics aye. Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted July 18, 2005 Share Posted July 18, 2005 http://www.retrotech.co.nz theres an article there too Link to comment Share on other sites More sharing options...
