Stacov Posted June 2, 2005 Author Share Posted June 2, 2005 well that was a waste of time got it all put back together starts fine but the same thing happens as last time that made me think it was the cambelt the cambelt slips off the dizzy pulley and moves forward/backwards so like it goes half off then back on its beyond me and doesnt matter what the tension setting is it still does it now this has just pissed me off. AND i dont want it anymore lol any ideas on what can cause this? Quote Link to comment Share on other sites More sharing options...
RT Posted June 3, 2005 Share Posted June 3, 2005 Sounds like it's not lined up properly?? I don't see how it can slip off.. can you post a pic? Yeah Sierra brakes can be made to fit. I'm assuming you're talking about a disc conversion on the rear? You have to make up brackets to hold the callipers though. I used to have a link on how-to for that.. I'll see if I can dig it up. Quote Link to comment Share on other sites More sharing options...
Stacov Posted June 3, 2005 Author Share Posted June 3, 2005 Hey RT i think i found the problem. The tension idle bearing? I think thats what its called. Anyways its meant to spin and control where the cambelt goes i think. The bearing in it is worn as it doesnt even turn. So the cambelt just rubs on it and goes all over the place on the pulleys I took it off can turn it by hand but it doesnt move freely and it makes scraping noise. im pretty sure this is causing all my problems what ya think ? Quote Link to comment Share on other sites More sharing options...
RT Posted June 3, 2005 Share Posted June 3, 2005 yeah probably! Do you mean the tensioner pulley? yes it's supposed to spin freely. anythng that rubs on the belt will cause it to go all over the place and wear it out in no time. Quote Link to comment Share on other sites More sharing options...
Stacov Posted June 3, 2005 Author Share Posted June 3, 2005 yes thats what i mean im now 100% sure its that now to put a second hand one on or try buy a brand new one? Quote Link to comment Share on other sites More sharing options...
RT Posted June 3, 2005 Share Posted June 3, 2005 don't think you can buy new ones.. but theres loads of 2nd hand ones around. Quote Link to comment Share on other sites More sharing options...
Stacov Posted June 3, 2005 Author Share Posted June 3, 2005 yeah ill just take one off another pinto i got sitting down the road just gotta go pick it up hehe thanks RT for all ur help ur been awesome man ill let ya know how i get along once the new tensioner pulley is on Quote Link to comment Share on other sites More sharing options...
esky boi Posted June 3, 2005 Share Posted June 3, 2005 Hmm well im just putting the belt on my pinto now too. But im having a major problem getting the cam timing setup properly, like it will NOT line up. It either sits about 8 degreees advanced or 8 degrees retarded Ive had the head skimmed 60 thou and I was thinking this might have something to do with it Anyway, ive heard you can have the cam timing slightly advanced/retarded to get more power on a pinto? but with that much taken off the head that probably wouldnt be a good idea, as piston to valve clearances could be getting abit close aye? Quote Link to comment Share on other sites More sharing options...
Stacov Posted June 3, 2005 Author Share Posted June 3, 2005 Hmm well im just putting the belt on my pinto now too.But im having a major problem getting the cam timing setup properly, like it will NOT line up. It either sits about 8 degreees advanced or 8 degrees retarded Ive had the head skimmed 60 thou and I was thinking this might have something to do with it Anyway, ive heard you can have the cam timing slightly advanced/retarded to get more power on a pinto? but with that much taken off the head that probably wouldnt be a good idea, as piston to valve clearances could be getting abit close aye? not sure aye i had the same problem everytime i tighten the cambelt it would move the cam away from its timing marks, but when i started the engine went first pop sounded/idle alright im sure RT will beable to help ya goodluck bro Quote Link to comment Share on other sites More sharing options...
esky boi Posted June 3, 2005 Share Posted June 3, 2005 Yea its really pissing me off aye, I spent hours trying to get it right today with no luck But yea im sure RT will have some clues Quote Link to comment Share on other sites More sharing options...
Stacov Posted June 3, 2005 Author Share Posted June 3, 2005 ahh hours lost on simple things i know how ya feel im not even sure if my timing is bang on but i bet its pretty close aslong as the car pulls hard and can poor smoke off them tyres should be sweet ur engine might be modded more then mine so i dunno about ur timing hell i dont even know what mods have been done to mine lol apart from a lumpy cam aftermarket flattops, larger oil garlerys thats all i know sucks buying engines off other people heh head looks abit different to normal ones too so maybe work done to that rofl i was just thinking if u move the arrow on the cam alittle bit past the hole then tighten the cambelt is should move onto the hole and be bang on was just thinking about. u tryed that? Quote Link to comment Share on other sites More sharing options...
esky boi Posted June 3, 2005 Share Posted June 3, 2005 Yea tried that aswell aye, think ive just about tried everything lol. Maybe I might just leave it advanced or sumthin and just see how it goes Or see what RT has to say Quote Link to comment Share on other sites More sharing options...
esky boi Posted June 4, 2005 Share Posted June 4, 2005 Might separate it start a new topic on that one aye Quote Link to comment Share on other sites More sharing options...
Stacov Posted June 6, 2005 Author Share Posted June 6, 2005 just a update everything is now a GOGO put a new tensioner pulley on and now its all sweet, also put on the cam cover just incase it ever did decide to come off it would get hit back on hehe now for brakes, exhaust, and fix the electical problems and she should be on the road haha maybe in a year Quote Link to comment Share on other sites More sharing options...
