Ned Posted May 11, 2005 Share Posted May 11, 2005 I thought you had some rust in the front guards too did you get that fixed or am I seeing things It was dark when I saw your car it does, lost of it but i have spare ones so that'll be fine. also, its not srtuctural so it doesnt matter for a WOF Quote Link to comment Share on other sites More sharing options...
Muzzie Posted May 11, 2005 Share Posted May 11, 2005 I thought you had some rust in the front guards too did you get that fixed or am I seeing things It was dark when I saw your car it does, lost of it but i have spare ones so that'll be fine. also, its not srtuctural so it doesnt matter for a WOF Hehehehe, nobody can see my rust in the guard. I used a half tin of bog on it, still gotta touch up a couple places though. Gonna do some more bogging today actually. Quote Link to comment Share on other sites More sharing options...
Guest Eddie W Posted May 13, 2005 Share Posted May 13, 2005 Dutch, etch primers like PA10 are formulated to etch a key in the metal surface for a better bond to the metal. As I said above the etch effect only works properly with a light first coat. Once the first coat has done the keying then subsequent coats can be as thick as you like. Eddie Quote Link to comment Share on other sites More sharing options...
Dutch Posted May 13, 2005 Author Share Posted May 13, 2005 Ok, so it's a little like sanding, but with paint... neat. Is the primer a rust retardent, or does that go on after the primer? Quote Link to comment Share on other sites More sharing options...
droppdkp Posted June 24, 2005 Share Posted June 24, 2005 Ok, I knew there was a page here. I got sick of waiting and became inspired to attack my rust myself. I have metal based bog, disk for drill, spray primer and spray on paint. I've heard you have to let the rust dry completely before taking it off? Is rust kill and etch primer essential? I'm also knew to this and need help. Cheers Quote Link to comment Share on other sites More sharing options...
esky boi Posted June 24, 2005 Share Posted June 24, 2005 Yea bo, its best to let the rust dry before going at it, just makes things easier thats all. Youll want to grind it all off, or as much as you can, depending on where it is and stuff. Try to get the whole area down to shiny bare metal, but if you cant then youll need to spray on some of that rust kill stuff. Its best not to bog straight onto bare steel, so etch prime it first, then bog it, then prime with normal primer and then paint Quote Link to comment Share on other sites More sharing options...
