esky boi Posted May 3, 2005 Share Posted May 3, 2005 I have a 2litre cortina motor and the guy I got it off said it had a lumpy cam. So I had a look and it does look lumpier than a standard one... the number on the front of the shaft is FR21. Not too clued up on pintos yet, so just wondering if any of yous know the specs of that cam?? chur Quote Link to comment Share on other sites More sharing options...
Jerm Posted May 3, 2005 Share Posted May 3, 2005 Pinto 2000 SOHC FR21 Mild Road 2000 - 6000 Inl 10.4mm Exh 11.04mm Inl 262 Degs Exh 272 Degs 26/56 71/21 105 Degs Inl 0.20mm Exh 0.20mm http://www.kentcams.com Quote Link to comment Share on other sites More sharing options...
RT Posted May 3, 2005 Share Posted May 3, 2005 yeah thats a Kent bump stick.. but not very bumpy. FR stands for Fast Road and the 21 is a mild version. Great for a bit of an upgrade on an otherwise relatively standard engine, standard valves etc. Good idle and mid-range power. But don't expect wonders, especially if the head hasn't been ported. Pinto's must have a good port to make power. If you were going to run aftermarket goodies like double valves springs, twin carbs etc etc then you'd want a FR31 or 32. The FR21 is great if you want to turbo it though. Quote Link to comment Share on other sites More sharing options...
esky boi Posted May 4, 2005 Author Share Posted May 4, 2005 Cool, sounds good. Should be about right for what im after then. Cheers guys Quote Link to comment Share on other sites More sharing options...
davidian Posted May 4, 2005 Share Posted May 4, 2005 did u buy that cortina off the guy out east? $500 or so? Quote Link to comment Share on other sites More sharing options...
esky boi Posted May 4, 2005 Author Share Posted May 4, 2005 Nah bro, just got a motor, brought it off a mate. Whats this cortina out east, was it any good? Quote Link to comment Share on other sites More sharing options...
