Guest sdewyz Posted April 10, 2005 Share Posted April 10, 2005 ...quite simply,are 40mm twin Dellortos a good option for this 1600 engine on the 73 colt.Also had an idea of getting the standard twin carbs of a 4G52.At this point the Dellortos are quite easily optainable. Any useful comments appreciated. Quote Link to comment Share on other sites More sharing options...
lowlancer Posted April 11, 2005 Share Posted April 11, 2005 To be honest, you should go for a single carb like a 32/36 if I'm not mistaken. Plentiful and cheap, easy to maintain compared to a twin carb. But then again..... Twin 40's I plan on getting a 32/36 for my 4G32, once it's manual Quote Link to comment Share on other sites More sharing options...
kyteler Posted April 11, 2005 Share Posted April 11, 2005 ...quite simply,are 40mm twin Dellortos a good option for this 1600 engine on the 73 colt.Also had an idea of getting the standard twin carbs of a 4G52.At this point the Dellortos are quite easily optainable.Any useful comments appreciated. If you haven't done any headwork and don't have headers, then forget about it, it'll go through too much fuel and bog down and be a waste of time unless you jet the dello 40's really low. I would suggest going with the standard 4G52 twin carbs. Quote Link to comment Share on other sites More sharing options...
Guest sdewyz Posted April 11, 2005 Share Posted April 11, 2005 while we're on the topic ,could the intake manifold be used also of the 4G52 or get one made?And thanks for the advice on the carbs.I think I'll go with the standard twin carbs of the 4G52 as I'm trying to keep the car original as possible. Quote Link to comment Share on other sites More sharing options...
kyteler Posted April 11, 2005 Share Posted April 11, 2005 I have absolutely no idea about compatibility between Mitsi engines but lowlancer probably does, if not him then there's bound to be someone on here who will know. Quote Link to comment Share on other sites More sharing options...
lowlancer Posted April 21, 2005 Share Posted April 21, 2005 At a guess, I'd say no, but I wouldn't really know. Why don't you go for the 4G32 twin carbs? Quote Link to comment Share on other sites More sharing options...
