Defcon Posted March 29, 2005 Share Posted March 29, 2005 Word, having real trouble bleeding my brakes. I just fited a new set of custom rotors and calipers-ive bleed the back and now am bleeding the front. Problem beeing ive just spend 3 days and 3+ letres bleeding the left front caliper and there is still air coming thru! i still have to bleed the right front! I dont think this is normal so could any one suggest the problem? Thanks, def' Quote Link to comment Share on other sites More sharing options...
SYKOV6 Posted March 30, 2005 Share Posted March 30, 2005 are all of ur joints tight sounds like its sucking air from somwhere Quote Link to comment Share on other sites More sharing options...
RT Posted March 30, 2005 Share Posted March 30, 2005 When I emptied my system and fitted new brake hoses it took me ages to bleed the air out too! I began thinking something was wrong but eventually it calmed down. but do check everything is sealed so that it's not sucking in air somewhere. Quote Link to comment Share on other sites More sharing options...
dabuzz Posted March 30, 2005 Share Posted March 30, 2005 try clamping off each line once youve bled it and clamp l/h to bleed right hand etc is your propotioning valve working properly??? but as the others have said check all joints for leaks Quote Link to comment Share on other sites More sharing options...
Defcon Posted April 3, 2005 Author Share Posted April 3, 2005 Thanks for the info, as for the cecking joints for air leaks, how exactly would i got about this? guess the only way is to loosten it and align/tighten them. Will prob grab a few mates round and bleed it manually, maybee the valves busted. Thanks, def Quote Link to comment Share on other sites More sharing options...
