Stacov Posted January 28, 2005 Share Posted January 28, 2005 Going to compression test the 1600 tomorrow what should the compression be around ? 100mark ? Quote Link to comment Share on other sites More sharing options...
esky boi Posted January 28, 2005 Share Posted January 28, 2005 Straight from the haynes manual for the 1600 it says: 158-184 psi at starter speed Quote Link to comment Share on other sites More sharing options...
Stacov Posted January 28, 2005 Author Share Posted January 28, 2005 lol WOW thats alot haha they must of tested one healthy 1600 to get those hehe Quote Link to comment Share on other sites More sharing options...
Draizuh Posted January 28, 2005 Share Posted January 28, 2005 Welll the haynes manuals were made around the time the escort was. so they had healthier ones then [/u] Quote Link to comment Share on other sites More sharing options...
Stacov Posted January 28, 2005 Author Share Posted January 28, 2005 just did a compression test 1 cyliner 150 2 cyliner 150 3 cyliner 90 4 cyliner 150 So not good theres no knocks/bangs so could be the head. A burned valve or something? i got a spare 1300, what will happen if i put the 1300 head on the 1600 block? will it raise compression or make it worst? or am i better off putting the 1300 in now and striping the 1600? Quote Link to comment Share on other sites More sharing options...
v3k Posted January 28, 2005 Share Posted January 28, 2005 I think the next step is a leak test. Not too sure how you go about it but Im sure someone here will know. Something to do with finding where the pressure is escaping. Quote Link to comment Share on other sites More sharing options...
Stacov Posted January 28, 2005 Author Share Posted January 28, 2005 well i know theres leaks in inlet manifold and exhaust but that shouldnt make a differences when compression testing anyone know what the valve timing inlet and outlet should be ? *UPDATE* just got cyliner 3 to test @ 130 from 90 by just changing the valve timing on the tappets but i really need the proper specs to do it properly thanks Quote Link to comment Share on other sites More sharing options...
Draizuh Posted January 28, 2005 Share Posted January 28, 2005 even tho youve found your problem ill add that putting a bit of oil into the problem cylinder and checking it again can also raise the comp... and if it doesnt it brings forward the problem of your seals.. Quote Link to comment Share on other sites More sharing options...
Stacov Posted January 28, 2005 Author Share Posted January 28, 2005 Ok will try that still gotta put new spark plugs in as only 2 are working properly hehe ill be getting the car tuned probably in the next couple of weeks once my mate has moved to his new house so no rush i guess. But i tell ya what getting the cyliner 3 to run at 130 it goes way better and idles properly now too Quote Link to comment Share on other sites More sharing options...
Jerm Posted January 28, 2005 Share Posted January 28, 2005 valve timing? you mean the tappet clearances ? should be inlet 10 thou (.25 mm) exhaust 22 thou (.55mm) and i think that is at cold.. so you best to leave it over night.. and you will have to put the car in gear and get the valves fully closed .... so that the followers are o the heal of the cam.... best to consult a manual if you have one... Quote Link to comment Share on other sites More sharing options...
Stacov Posted January 29, 2005 Author Share Posted January 29, 2005 alright will do jerm cheers Quote Link to comment Share on other sites More sharing options...
