Guest escort_boy Posted December 1, 2004 Share Posted December 1, 2004 prety much everytime i have 3 ppl in my car, i get a knocking noise. its like something is moving round and knockin on a pipe, it gets faster and the car goes faster, but i have yet to find the problem. anybody have an idea Quote Link to comment Share on other sites More sharing options...
RT Posted December 1, 2004 Share Posted December 1, 2004 you driveshaft hitting the exhaust if it crosses it? or perhaps you axle hitting your exhaust due to weak shocks? Is it coming from under the car of from the engine ? Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted December 1, 2004 Share Posted December 1, 2004 its from under/ to the bak of the car. ill have a look at those to things tho Quote Link to comment Share on other sites More sharing options...
Guest Jamezuu Posted December 1, 2004 Share Posted December 1, 2004 Is it come from one side of the back of the car, could be wheel bearings getting buggerd. Easy to do and about $45 for a kit. More center sound would likely be a universal as more weight in one area of the car would make it run at a different angle which it may not like. Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted December 1, 2004 Share Posted December 1, 2004 any way to tell if it is the universal? like any easy tests Quote Link to comment Share on other sites More sharing options...
lowlancer Posted December 1, 2004 Share Posted December 1, 2004 Cortina kid had a similar problem with his cortina, turned out to be an axle bottoming out or the diff scraping on something, or something, result of having buggered shocks Quote Link to comment Share on other sites More sharing options...
Guest Jamezuu Posted December 1, 2004 Share Posted December 1, 2004 Grab both sides of the joint, ie the diff flange if possible and the dirveshaft and give them a turn in the opposite way, if theirs play it may be stuffed. Do you get any woble or vibrations in the steering wheel when loaded and unloaded? Quote Link to comment Share on other sites More sharing options...
esky boi Posted December 1, 2004 Share Posted December 1, 2004 if it's doing it when there's more people in it, and the noise is coming from the back of the car, then i'd say it's the exhaust hitting the diff or something, probably because of broken or weak mountings. Id check it out aye. Quote Link to comment Share on other sites More sharing options...
