GARDRB
Everything posted by GARDRB
  1. Hello Wellington GCs, I have a good friend who has just moved to Wellington who isn't a car person. She's got a Holden Cruze and has just had a bunch of thermostat stuff done up here. She's now moved to Welly and has a check light and code 89 which appears to relate to the sensor in the thermostat. Is anyone around that area that would be happy to have a look or can someone point me in the direction of a good workshop? She's been recommended Kilbirnie Motors but was hoping to find someone closer. If anyone has any suggestions or wants a new Wellington friend sing out. She and her fiance are into board games and TTRPG stuff.
  2. that's what she said
  3. I think this is the setup I'm gonna end up with. I'm gonna try and heat the hose a bit to get a little bit of a curve into it
  4. Yeah kinda worried about what Dr Dre has been teaching him at the High Penetration Academy
  5. Ramen all the air into the engine
  6. 600mm is gonna be pretty big for most printers, but someone like PCBway might be able to do it? You could also look at SLS Nylon or something through them and have a finished part to run with? https://www.pcbway.com/rapid-prototyping/3d-printing/
  7. So I'm no @Roman or @kpr and I know you've already fiddled with your inlet manifold, but now that Dave has proven we can 3d print metal easily and cheaply enough, could you do a curved runner behind the throttle body that lowers the throttle a little to get a nice entry angle? Would this leave you with atomised fuel pelting into the runner wall, or will the airflow suck the fuel round the corner? I've been playing with the sheet metal tool in Fusion and thoroughly enjoyed it. Could be a good next move after cardboard and then order a cut and folded box? Could you do silicone connectors between the throttles and the airbox to reduce the effect of vibration and put the bell mouths in the back wall of the box? Old mate in Kaiwaka with the widebody GTR fronted Stagea has been doing 3D printed modular moulds and producing composite parts off them (OMG just posted my first spoiler and it worked)
  8. I really like the idea of this, but you have to drill a hole in your brake res, and so if there wasn't enough fall to the clutch cylinder you might be in for a bad time https://www.chasebays.com/collections/universal-chase-bays/products/chase-bays-clutch-feed-adapter-for-brake-booster-eliminator
  9. So I went looking for the camber thing. Here you go, 1.5degrees neg or half a degree more than maximum camber specified by the manufacturer.
  10. Haha I'm in the crusty bilstein crew, but I think the keeper springs on mine might ruin any potential to be a criminal
  11. Because I have a spicy brain I'm going to make you all suffer through 12 years of out of order updates based on which photos I find first. The diesel wagon comes factory with a larger s-series diff compared to the normal KE70, but this still wasn't going to cut the mustard because V8 and because I wanted an easy LSD option. I looked at options, first was G-Series Hilux, which I decided was heavier than what I needed, and settled on an F-Series. Now I needed to find one. Some of you may have heard of a Crown foamer called @sheepers, @Snoozin suggested I hit him up about a housing, and he supplied me with an MS85 drum brake diff. Somehow it made it's way to me and I turned it from a 5-stud, 3-link drum brake diff into a 4-stud, leaf sprung diff with AE92 FXGT calipers and S14 discs. We drew up some caliper adapters on paper and got them laser cut (I'll probably make better ones now that I have skills and shit) and an engineer a friend in Silverdale uses welded and redrilled the axles before I chucked some Landcruiser studs in them. The amount of time it took to get the axles done really makes me scared of breaking one, but we will see how we go. The LSD was bought off someone on Facebook and is an Altezza A-series torsen of a forgotten ratio, most likely 4.1, my same SIlverdale friend sent it to our mate Kayne Barrie for a bit of a freshen up and to be put into the Crown carrier. It's got a solid pinion spacer and he has really high standards and attention to detail, so I'm sure it will be a nice diff. I set about making some really ugly brake lines which was a learning experience and I have just recently found out how dumb I am, because they run through where the bump stop needs to land, so I'll probably redo them, maybe even with braided line if I get super lazy. Keep in mind I'm a computer guy, and that this is my first rear wheel drive car.
  12. Yeah it’s sold as Copper Nickel, it’s from Ali Express though so I’m a little dubious
  13. Also in "Today stuff shows up for my Corolla" @di0n received the thread for my interior today The plan is to do my door cards in a similar fashion to these FJ45 ones he did, but black and with the orange stitching to match the FXGT steering wheel. I'll design and cut the cards and get him to deal with the stitching side. I've got some ideas for map pockets and armrests too so I'll see how I go. I'm thinking I'll do a detail section with a black basketweave vinyl too
  14. Max showed up this afternoon with my sump which he has had modified to fix a leak and clear the steering rack better. I've drawn the lower pan flange in fusion and I'm going to try and design a wider slimmer winged pan to give me some more ground clearance and try and get the sump up in line with the crossmember. He's also had a 4age throttle body flange welded onto his 2T intake manifold so we can use the 4age throttle and it's corresponding TPS so I'll update his thread soon hopefully
  15. I've messaged @KKtrips with the solution for that. He said they were looking into it. It will be in your spam
  16. Posted in the wrong thread coz I'm dumb
  17. This is where I asked Clint
  18. Yeah I think remote is gonna be the way to go. Just have to work out the cheapest way to do it.
  19. Leeeeegend, @Dudley created a movement and he's a bit of a force
  20. Yeah good point, I misread the instructions, it didn't make sense to me that that could be an inlet, must have been their use of "rear" on what I would consider to be the front of the cylinder because it's facing forward. Back to the drawing board.
  21. Also, because Toyota so kindly put my rear brake line and my fuel lines down my tunnel, nice and high and out of the way of the road, and I have a fast spinning driveshaft in there that could explode and destroy everything in it's path, I've got to move my hard lines for cert. So I've bought a tube bender and a roll of copper brake line and just need to get fuel line. In their infinite wisdom, Toyota decided to have the passenger's rear floor pan stick down lower than the chassis rail, so it looks like I'm going to have to run the lines out through the side of the engine bay and down the outside of the chassis rail next to the pinch weld to avoid the dip in the floor and keep them up nice and high
  22. My new reservoir showed up from Ali today, so I threaded it in and realised I couldn't open it under the pinch weld on the firewall. So I went and got an adapter to screw it into the AN3 front port instead of the AN4 rear port Now it fits nicely in front of the pinch weld.
  23. Discuss here Ok, so I bought this off @di0n sometime in 2012, needless to say, things haven't progressed quicker. It now has more engine than it ever needed and is in 1800 pieces, but sometimes @Dudley talks me into working on it. The engine is hopefully out for the last time at the moment while I do some bits and pieces like moving the brake and fuel lines out of the tunnel and making sure I'm gonna have enough clutch master for the hydraulic release bearing. The current spec list is: 1986 CE71 Diesel Corolla wagon. 1995 UCF20 second generation 1uzfe Factory 1UZ auto bell housing with an adapter plate Factory-fitted W56 (I think it's a 56) from behind the diesel 3S-GTE flywheel with Hilux Surf clutch Quartermaster hydraulic release bearing Tilton 76-series stubby clutch master with Chinesium reservoir Shortened factory driveshaft because the gearbox is pushed back to get the engine as low and far back as possible. Ex @sheepers Crown diff with Altezza LSD head with the KBM treatment. AE92 FXGT rear calipers and non-turbo S14 discs Ex C's Garage reset leaves and shocks MRP Wilwood kit Chinesium smaller brake booster MRP front Coilovers Early Evo/GSR Recaros on Bride rails A Racetech drivers seat on a Scarles bracket. Factory ECU Siemens fuel pump on the end of the factory fuel feed in the tank. 14x6.5 Starsharks with Direzza ZIIs
  24. Yeah, I've opted for this one. I actually read the measurements this time too. It looks like it may neeeeearly screw into my master cylinder too which will save me in fittings https://www.aliexpress.com/item/1005003761972381.html?spm=a2g0o.order_list.order_list_main.5.620018027N2rz8
