mikey
Everything posted by mikey
Auckland OS Winter shed tour - Saturday 11th July -
mikey replied to Threeonthetree's topic in Upper North Island Region
I'm basically keen as fuck for this. Can I do skidz outside everybody's shed? -
You're welcome to the axles, they're just taking up valuable space. And gimme ya email and I can send you the drawings I have for the brake brackets. Keep in mind I've not actually used the drawings to make any brackets from. This chap used it as a starting point and CNC'd some thou: //oldschool.co.nz/index.php?/topic/43593-datsun280zs-datsun-280z/?p=1323846
Sweet, I have some supposedly shortened S15 axles if they're any use to you? They're 27 spline I assume? I was gonna do something with them but they look too long too me and it all got too hard. I even designed some 3x2 CV to 4x1 adapters I was gonna get CNCd. Yeah, my rear end makes some pretty funny noises too. I kinda hoped swapping the diff mount etc would sort them all out but there's still the occasional clunk when going from standstill. Just another thing on the very long list!
Sweet, so your front mount is solid now? That was an option too but I was worried about vibrations. Also some peeps reckon it's a bad idea to have the diff part solid and part soft mounted as things start cracking, but I've got no experience with that. I was keen to go to CV's as well, but have left it for a later project. I'd probably just go this route if I did it to save all the hassle: http://www.wolfcreekracing.com/index.php?option=com_content&view=article&id=72&Itemid=61 My diff is a Nismo CLSD.
It's so much better. It still gets some vibes but nothing like it used to. It happens when I accelerate from 50-100kph with the foot flat. It never used to happen with the old engine but it's just 'cos the new one can twist the diff nose higher. Most people put in something called a Ron Tyler diff mount but it's a bit of a hack if you ask me. Been liking ya build BTW; great attention to detail.
So I've ticked two pretty big things of ma list and I'm stoked with the result. I've finally got a good LSD in and the front diff mount is heaps better. This was the old front mount, it has some rubber between the two steel plates. But when you out your foot down the nose of the diff lifts as the rubber stretches, the angle of the driveshaft changes and the uni joints start hella shaking. So I made a jig CHOP Put some tube in there that was the right ID for some poly bushes. All ready to go back in I also had to get some fancy stub axles from the states which are 27 spline but have the Datsun bolt pattern. 27 Spline means I can run lots of more modern Nissan and Subaru diffs. So now i'm just like pulling 11's all round town....
- 78 replies
After taking this thing to the Taupo track and driving my brother-in-law's super sweet '69 911T, I realised it needs a bit of love. The track day went well buuuuuut, it's just kinda annoying to drive; it needs some finishing. I done a list: Install LSD Come up with a better front diff mount Convert from drums to disk brakes in the rear Seal filler neck Get alternator serviced (yet again) Move alternator to the left side of engine for better cooling Find more exhaust clearance Add some heat shielding to the firewall/tunnel to keep cabin temps sane Install carpet underlay So, today I removed the R180 VLSD, it's a Subaru thing and waaaay back on post numero ono I made the mistake of installing it. It puts the "slip" in LSD. So I have a some other CLSD thing which I'll get Steelie Gears to setup for me, I just have to source some 27 spline stub axles to suit Datsun half shafts (about $500USD, which is actually a lot cheaper than what it took to get the VLSD to work). While it's out I'm gonna change the way the front diff mount works. The factory setup sucks because it allows the nose of the diff to lift when you put the foot down and the whole car starts shaking because of the hinky uni-joint angles. It probably makes sense to convert to disks at the same time. I'm sure it's just me but drums seem awfully difficult to maintain and keep adjusted. I think I have all the bits I need to make this happen except some custom calliper bracket thing I'll have to make. These pics for fred are from when the car was in NZPC last year:
- 78 replies
- 16
All my tests were from cold unfortunately. I'm not really game for getting it retested and re-repaired again; if it is broken It'll just happen all over again. The wiring all checks out and is pretty simple, I can't see where I've gone wrong there. Have 80A relay, will plop that in and be done with it. Even though the alternator is rated around 80A it never runs anywhere close to that.
Actually, I'm just gonna admit defeat and put an 80A relay on the B+.
I just checked and IGN & sense wires are correct way around. I'm all for the lazy but the relay on IGN or sense wont help as it's draining thru B+. Not sure I can put a relay on B+ as it's mega-amps? I'm also not convinced it's a diode as it's fine if I disconnect/reconnect B+ and it's just been rebuilt & tested. Even if it is a diode replacing it isn't the best fix either as that'll be my 4th alternator in 18 months and surely the same thing will happen again. So if that's the case I'll have to find a work around.
Yeah it still drains the battery if I disconnect the ign and sense wires leaving just the B+. I'll check tonight that they're the correct way around.
My alternator has been draining my battery in my 240z since I swapped the engine and it's a pain in the dick. It takes around 4 days to drain the battery to the point I can't start it. The symptoms are after driving the car letting all the electronics chill out for a minute the battery will drain 0.17A. If I then disconnect the alternator B+ wire it'll drop to about 0.02A at which point I can reconnect it and still only get 0.02A. I've tried disconnecting all sorts of things but the only thing that helped was the alternator. This is my third alternator since the swap and they're pretty expensive. The first two I swapped because I was pretty sure they had bad diodes - the place I've mounted the alternator gets pretty hot & I've since built a shroud for it - they had slightly different symptoms thou, after reconnecting they'd still drain hard out. The one I have now has professionally rebuilt and tested and has done this since I put it in. So have I done something wrong with my wiring? The obvious answer is I have a bad diode, but it seems odd that disconnecting and reconnecting the B+ fixes it. How can I work around it? I'm almost considering having a switch on my B+ terminal to isolate it. I potentially could have a relay on it so it switches on/off when I start the car. My concern is the amount of amps it'd have to deal with? CONFUSE
Leadfoot Cruise Part II - Saturday, 1st November, Hahei
mikey replied to BDA780's topic in Upper North Island Region
I promise not to be horribly hung over this time and on time! Yeah sorry about that. Me and Pais are staying in Ha Hei for the night now. -
Better late than never, I'M IN! -
Ummmm.... THIS IS AWESOME.
Nevermind....
- 1 reply
Does anyone have a bearing separator I can borrow for a night? Like this fella: I'm supposed to be going to Hampton Downs this Sat but one of my bearings just shat the bed.
Somebody left it in my letterbox with an Oldschool card. I was pretty sure it was you winkface! Btw, your trip looked aceness.
I <3 Miley.
- 78 replies
Yeah, the adapters seem to be the go. Way easier than finding the right companion flanges by the sounds. So I'll measure everything up a couple more times and then make it happen.
Bummer. I'll try and research other companion flanges with 25spline and 3x2 CV's. Cool, good to know. If companion flanges are impossible to find then this might be the go.
Oh, good call. Sounds like 280zx companion flanges will definitely work, they fit the 25 spline stub axles on the early 240 but have the 3x2 CV bolt pattern. Otherwise surely one of those other options will work. Sweet!
So I bought a Nismo LSD with some shortened axles from an S15. After doing some measurements I think I can make an adapter to go from the four bolt companion flange on my hubs to the 3x2 bolt CV bolt pattern and if I make it around 25mm think it'll put the CV's in the middle of their range. This is a shot of the axles I have Am thinking I can make some adapters like this Have you any thoughts or feelings on this tomfoolery?!
Are these TC rods certable? Looks like they've taken stock rods, cut and welded a threaded sleeve on. If they are, ima buy them.
So this happened. I'm not sure what's going on. These are the facts: I don't have spark I can connect to the ECU with an ODB tool There are no DTC's The fly-by-wire throttle doesn't seem to be reading anything, which I think is unusual. It has stuttered a little bit for the first 30 seconds the last few times I've started it After work tonight it stuttered quite a bit for about a km then died. I thought it was out of gas. I have fuel pressure at the regulator in the engine bay. I'm at a bit of a loss so far. But am shattered so hopefully it'll come to me in my sleep!
