I have a 2t-geu with efi stripped off. Running 2 40mm dcoe webers, Electronic ignition and worked cams, ported and polished head.
has a facet fuel pump and have had the carbs dyno tuned. Haven't got adjustable cam gears. engine work was done about 7 years ago and the project has never been fully finished. partially due to lost interest due to running issue! Have recently renewed my enthusiasim but need to fix 'Gurggle'.
When i use even just partial throttle below 3000 rpm the engine just gurgles. once over 3000 ish rpm theres no problem! it revs out faster than i can change gears. but thats not what i want!!!! thinking maybe its cam timing issue and i need to spend money on adjustable cam gears but over and above that... ive lost original paper work for the cam grind etc... Any thoughts?
