WIREDUP
WIREDUP's Achievements
Advanced Member
Advanced Member (3/5)
7
  1. to explain coper sheet lay on what you want to gasket tap around with rounded end ie ball pen hamer normally from here you can break out gasket or have to trim with blade to fit
  2. same principle coper sheet at x amount of .00 tap with ball pen or other u tube coper = soft finsh and fit love oldschool find a fault not a thought
  3. gasket paper of corect ish and a ball pen hamer maker your own if you cant buy one ?
  4. Auckland has Pt chev dog park and Watiroa (remuera ) as the big dog parks I have a 1.5 year old American bulldog X female any off lead with dogs with recoil would be gold my bitch don't come back
  5. I operate wired up Electricians can do this for you at a fair price see www.getwiredup.co.nz see viewtopic.php?f=1&t=32503&hilit=garage+wiring for a os review
  6. Do the cam and crank timing marks line up make are you afew teeth out or not on the firing stroke
  7. have you synchronized/Balanced the carbs with a http://www.palmside.co.nz/product_pcid_15854.html found this worked well for me to get the carbs Balanced also adjusting all idles 2.5 turns out adjusting from here via plug color chart normaly quarter turn or so to correct from rich or lean ( If carbs need cleaning or repair caberator specialist carlton gore rd where fine and ok price well ) A cheap timing light and a degree or two more advance and you should be sweat for under $ 130 if you need plugs and leads not much more new dizzy cap etc . I can lend you a carb Synchronizer from Mt Wellington and a timing light small deposit
  8. Do You need a Electrician to wire this new mega shed few fluros power points etc I run a one man band Electrical company
  9. Does anyone know a place in Auckland to make adapters to reduce spigot hole size .After reading this I think it may be my problem .My spigot hole of wheels is to big and Iget a random shake of death. It comes on out of the blue at various speeds
