160jsss
New Members
160jsss's Achievements
Member
Member (2/5)
0
  1. Is it the Kent motor they put the Datsun 1600 crank in to stroke it?
  2. If you use a xf dizzy you have to reverse the pinion drive and grind down some of the mounting flange otherwise you send shit loads of aluminium through your motor.
  3. 160jsss
    PAINT THREAD
    Ok another dumb question why are you meant to bog over bare steel rather than than etch primer I've got this thing about rust .I've always found rust under bog and I hate it but have to use some on a welded seam . once again thanks for your help
  4. 160jsss
    PAINT THREAD
    nothing wrong with with that shine I'm hoping to paint it silver still open reds a pain in the arse to paint
  5. 160jsss
    PAINT THREAD
    YES started going over the car with phosphoric acid . works well have to get some real 3M green pads the cheap ones from the House are crap I had read up on using phosphoric acid on the net some one had said to rinse after with water not a good idea instant flash rust Second coat of acid fixed that up will wax and grease remover take it of before I paint ? Any one used metal ready under paint it uses a Zinc phosphoric acid base or do I just stick to a Zinc first coat I do not want to see rust in a years time . Also we use Resene auto paint at work any good ? as I hope to get it cheaper than the 3M stuff from super cheap trade less %20 THANK YOU Guys for your help in advance
  6. 160jsss
    PAINT THREAD
    I'm hoping that right foot will mean no passing and the stuff we use you don't want near your car
  7. 160jsss
    PAINT THREAD
    Thanks bubblegoose for all your help trying to get the car painted soon I have surface rust on most of the car was planing on degrease then hit it with Phosphoric Acid then do I hit it with etch primer or just primer sorry for the hundred dumb questions I've read this right up but so much info to take in as always I want the best for the cheapest price . Its a Datsun so I don't want it to rust again The funny thing is I paint roads for a living but the stuff I put water based paint down at 200 microns and spray at 2000 to 3000 psi
  8. 160jsss
    PAINT THREAD
    has the 3M price tag thats for sure but 3m is 'usually good shit' I was thinking it was cheap ? thats why i asked if it was any good
  9. 160jsss
    PAINT THREAD
    Any one had a play with the 3M etch primer that supercheap sell
  10. Hi would this be of any use http://www.voltelectronics.co.nz/kits/a ... r-kit.html
