Everything posted by grunta
guesses on how long viton o rings will survive on throttle shaft? , im thinking around a year... or 12 x drives
- 86 replies
Got it installed , linkage works perfect , fired it up and ran ok when revving but wouldn't idle .. found leak with setting idol high ( so it would run ) and spraying engine start around the carb , throttle shaft bore is worn so I've got the carb apart and will sleeve with phoz bronze and bore ... photos to come
link is vid of throttle / kickdown , needs a wee bit of refining but you get the idea.. rose joint joins to throttle on carb and the other end of that lever has throttle cable... https://www.facebook.com/nick.grinter.3/videos/10154617217626746/
made a start on thorttle and kickdown linkage
2 barrel sitting in place, , just designing throttle and kick down linkage... oh and i finally painted (sacrilegiously) the rocker cover..
Runamucks - VG Valiant Sedan of Lawn Ornament & Rust
grunta replied to CUL8R's topic in Project Discussion
bloody rusty vals! hey what are your thoughts on treating inside the sills / cavitys? -
carb cleaned up and gasket made... 5/16unf nuts found in random nuts and bolts bucket - which is a feat in its self... had to die nut the studs as shit was fucked (highly technical term) looking forward to getting this sucker on..
- 86 replies
Hellnback's 1967 VC Valiant Regal - Discussion
grunta replied to hellnback's topic in Project Discussion
this is worth a look... http://www.hotrod.com/articles/slant-sickness-add-77-hp-mopar-slant-six/ -
grunta replied to KKtrips's topic in Lower North Island Region
i might pop down... -
im going for a slightly different look , have the air cleaner very similar to this off an 86 dodge truck.. going to get a sign writing mate to do the decals.. -
haha yeah! spread the cock love! -
cant see the pic you tagged me in...? -
great stuff man! -
manifold cleaned up and painted.. found an air cleaner off an 86 dodge truck which is perfect , 2280 holley looks great will try it out before i make a call on rebuilding it... #super6
awesome stuff man!! so much happy for you!
great work mate! looking good..
whats ya address , can send it down to ya... PM me info n carb... pretty sure its off a 318 but have heard these are ok to run on slants... maybe need smaller jets.. is missing tiny e clip off float breather but 1 will come with a new carb kit / ill try find one at work... also the guy i bought my manifold had another Cain 2 barrel manifold for $150 may have sold but worth giving it a shot... -
hell , you can have it for postage...easy come easy go -
ive got a carter bbd if u want it... $50. needs attention i just picked up a holley 2280 and a 2 barrel dodge manifold for mine... -
the old a-body cracked chassis by the steering box... classic.. Might as well throw one of these kits in while its out.. https://www.summitracing.com/int/parts/cca-k64-247-4/overview/make/plymouth -
hey man what the plan for your motor? rebuild ? -
ive used a bit of chain and a 10kg dumbbell as a slide hammer/puller and that worked well !
yeah i was thinking something like go off to a charcoal canister spec thing.cool as
